Need help on Spread COM Properties Equivalents in Spread .NET V11
Posted by: nchinta1 on 17 July 2018, 5:48 am EST
    Posted 17 July 2018, 5:48 am EST
    Hi Team,
    We are migrating our project from VB6.0 to VB.NET 4.7 .
    We are updating Spread .NET V11 from Spread COM 2.5.
    But there are many changes in the code when we upgrading SPread .NET 11.
    Spread properties has been changed and I want to know the Spread .NET 11 Properties of Spread COM 2.5
    I already gone through below URL , But I couldn’t find the properties which I want update in the code.
    http://help.grapecity.com/spread/SpreadNet11/WF/webframe.html#spwin-comequivalents.html
    Spread1.ActiveSheet.ActiveRowIndex = 1
        Spread1.ActiveSheet.ActiveRowIndex2 = i
        Spread1.ActiveSheet.ActiveColumnIndex = 1
        Spread1.ActiveSheet.ActiveColumnIndex2 = Spread1.ActiveSheet.ColumnCount
        Spread1.BlockMode = True
        Spread1.SortBy = 0 					    'sort by cols
        Spread1.SortBy = 0                                           'sort by rows
        Spread1.set_SortKey(1, 2)                               'name column
        Spread1.set_SortKeyOrder(1, 1)                     'ascending key 1 order
        Spread1.action 25
    Thank You…
    Naresh Chintala
  • Posted 17 July 2018, 7:53 am EST
    Hi Naresh,
    As per the documentation to sort a range of cells you can use SortRange method with Spread .NET. You can use the code as follows if you working with the unbound data:
     FarPoint.Win.Spread.SortInfo[] sort = new FarPoint.Win.Spread.SortInfo[1];
                // for sortkey and sortorder , initialize the sortinfo object with specified index and order whether ascending
                sort[0] = new FarPoint.Win.Spread.SortInfo(0, true, System.Collections.Comparer.Default);
                fpSpread1.ActiveSheet.SortRange(1, i, 1, fpspread1.ActiveSheet.ColumnCount-1, true, sort);
    I would suggest you to go through the documentation to understand the Sorting with Spread for WinForms here:
    http://help.grapecity.com/spread/SpreadNet11/WF/webframe.html#spwin-sorting.html
    Deepak Sharma
