Page break on every row after upgrade
Posted by: tosch on 23 September 2021, 4:03 am EST
  • Posted 23 September 2021, 4:03 am EST
    We have use Spread V11.45.20183.0 in out application and read/write to spread xml files.
    We have upgraded to V13.45.20191.0. All the files that were written in V11 and then loaded in V13 have the .Pagebreak property on all rows set to true.
    Please see the attached file where this problem occurs. You can just load it in the designer in V13 and see that there is a pagebreak on every row.
    Can you confirm if this is fixed in V14 or a more recent V13 version?
    Thomas
  • Posted 24 September 2021, 5:25 am EST
    Hi Thomas,
    Seems like your file was not attached correctly. Could you please attach it again so we can check it?
    I also tried opening a sample XML file (saved using Spread 11) with v13.45.20191.0 Designer but PageBreak for Rows is set as False.
    Jitender
  • Posted 24 September 2021, 5:43 am EST
    I hope the sample file is uploaded correctly this time.
    Thomas
    Swiss-Holz.zip
  • Posted 24 September 2021, 8:04 am EST
    Thanks for the sample file.
    I can confirm that this is a bug in Spread’s XML import.
    Unfortunately, the issue is still present in Spread 14.
    This will be fixed in Spread 15 [SPNET-20754].
    Jitender
