Problem Export to Excel
Posted by: patrik on 26 August 2020, 3:03 am EST
    Posted 26 August 2020, 3:03 am EST
    FpSpread1.SaveExcel("Test", FarPoint.Excel.ExcelSaveFlags.UseOOXMLFormat Or FarPoint.Excel.ExcelSaveFlags.SaveCustomColumnHeaders)
    This code working perfect, custom header are saved.
    But if I use that code and have disable “visible header” in Spread Designer under Settings.
    If I have a formula like:“=F9G10"
    After export and I open in Excel the formula will be::"=F10
    G11”
    If I use code below it’s work perfect, but if I sometime have a header it’s not exported.
    FpSpread1.SaveExcel("Test", FarPoint.Excel.ExcelSaveFlags.UseOOXMLFormat)
  • Posted 27 August 2020, 3:43 am EST
    It works as intended. When SaveCustomColumnHeaders is used, the exported worksheet will have row header and column header, which are inserted at the left / top of the worksheet. All formulas will be adjusted as same as user insert rows/columns at that position.
    Therefore, to get the correct output in generated Excel file while using SaveCustomColumnHeaders, in addition to un-checking the ‘Column Header Visible’ option in the Settings dialog, please set the value of Column Header Row Count to 0, in the same dialog in Settings menu.
    Ruchir
