Problem with FormulaTextBox
Posted by: stephane.chabeau on 27 October 2020, 2:30 am EST
    Posted 27 October 2020, 2:30 am EST - Updated 30 September 2022, 1:26 pm EST
    Hi
    Can you tell me why I can’t display the floating formula editor ?
    When i call “Dim editor As New FormulaTextBox”…etc
    Please, look at the attachment
    The .Licx file is present in my project and everything else works correctly
    thank you
    Stephane
  • Posted 28 October 2020, 1:02 am EST
    Hi Stephane,
    The nag screen means that the licensing system could not find a valid license while trying to run the application.
    If you are facing the issue only after adding an instance of FormulaTextBox, then I would suggest you to add the following entry in the licenses.licx file (generally present under Properties folder in Solution Explorer).```
    FarPoint.Win.Spread.FormulaTextBox, FarPoint.Win.Spread
  • Posted 28 October 2020, 1:21 am EST
    Your suggestion solved my problem
    Thank you very much
