Posted 27 June 2022, 12:18 am EST
Hi Ivan,
We have reported the issue to the development team. It seems like an issue with the targets file, as you are referring to Spread 15 from NuGet.
In the meantime, as a workaround, you can edit the targets file of the Spread NuGet package to work around this issue.
Change from:
<Exec Command="$(GCLMExe) $(MyBuildID) -lc $(IntermediateOutputPath).gclicx $(TargetFileName)"
Outputs="$(IntermediateOutputPath).gclicx"
IgnoreExitCode="true">
to -:
<Exec Command='$(GCLMExe) $(MyBuildID) -lc "$(IntermediateOutputPath).gclicx" "$(TargetFileName)"'
If you are using the packages.config approach then you can find the targets file at location similar to projectFolder\packages\GrapeCity.Spread.WinForms.15.1.0\build. If you are using PackageReference then you can find the target file at C:\Users\username.nuget\packages\GrapeCity.Spread.WinForms.15.1.0\build.
If you face any issues, let us know.
Avnish
[Tracking ID : SPNET-24123]
