Resize Field in Editing mode
Posted by: michael on 24 February 2019, 5:54 am EST
    Posted 24 February 2019, 5:54 am EST
    Hi …
    is there any way to Resize a multiline-Field in Editmode after the users enters a new line ?
    Regards,michael
  • Posted 25 February 2019, 7:26 am EST
    You may get Row’s height with GetPreferredHeight method and set it for the Row on Leave Cell event. It should work when you have MultiLine and WordWrap set to True for a cell/ column.
    Please have a look at code and attached sample for the same.
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
            Dim g As New FarPoint.Win.Spread.CellType.TextCellType
            g.Multiline = True
            g.WordWrap = True
            FpSpread1.Sheets(0).Columns(1).CellType = g
        End Sub
        Private Sub FpSpread1_LeaveCell(sender As Object, e As LeaveCellEventArgs) Handles FpSpread1.LeaveCell
            FpSpread1.ActiveSheet.Rows(e.Row).Height = FpSpread1.Sheets(0).Rows(e.Row).GetPreferredHeight
        End Sub
    Hope it helps.
    Reeva
    ResizeRowHeightAtRunTime.zip
  • Posted 5 March 2019, 1:35 am EST
    thanks for your help - magically now it seems to be working :slight_smile:
    in editing mode the .Multiline is the magic key Right ?
    michael
  • Posted 5 March 2019, 1:51 am EST
    Yes, you have to set the celltype’s multi-line property to true for the same.
    Reeva
