Rowfilter Help Needed
Posted by: brwood on 28 March 2018, 7:59 am EST
    Posted 28 March 2018, 7:59 am EST
    Good Morning. Here is what i’m trying to accomplish :
    I have a grid with several different columns. At the click of a button, I want the grid to programmatically rowfilter to only show certain rows.
    For example : Show if values in column A are greater than 50
    I am assuming I want to use a hiderowfilter? If so can you provide any type of basic code example for this?
    Also, They may want to filter by multiple things at a time :
    For example : Show if values in column A are greater than 50 AND values in column D are less than 10.
    Is this possible as well?
    Thanks for your help.
  • Posted 28 March 2018, 8:00 am EST
    Also, I want these rowfilters to happen entirely in code. Not through them clicking on a filter list.
  • Posted 29 March 2018, 7:34 am EST
    You can use the AutoFilterColumn method to filter in code .
    Here is the code snippet to implement the same, you can write the code in a button click event and clicking on the same would filter the rows in Spread based on one value in a specific column:
      fpSpread1.ActiveSheet.Columns[1].AllowAutoFilter = true;
              fpSpread1.ActiveSheet.AutoFilterColumn(1, "Flash",1); // 'Flash' is the value which is be used to filter
              fpSpread1.ActiveSheet.RowFilter.ShowFilterIndicator = false;
    Please refer to the documentation given here:
    http://help.grapecity.com/spread/SpreadNet11/WF/webframe.html#FarPoint.Win.Spread~FarPoint.Win.Spread.SheetView~AutoFilterColumn(Int32,String,Int32).html
    Hope it will help you. Please let me know if you have any queries further.
    Deepak Sharma
