Set Bold,Italic and Underline a group of cells all at the same time
Posted by: robertobonilla2007 on 8 September 2017, 2:00 pm EST
  • Posted 8 September 2017, 2:00 pm EST
    I need set a group of cell Bold,Italic and Underline all at the same time. not individual like the example below, if not all together
    Dim si As New FarPoint.Win.Spread.StyleInfo
    Dim defFont As Font = FpSpread1.Sheets(0).Models.Style.GetCompositeInfo(f, c, -1, si).Font
    Dim rangeFont As Font
    rangeFont = New Font(defFont, FontStyle.Bold)
     How can i do? Crying
     Thanks in Advance
     RB
    I didn't find a way to define these three different style using the same object.
    You may create three different font styles using Font and then you can apply those font styles to a range of cells Below is the code snippet to do the same.
            FpSpread1.Sheets(0).Cells(1, 1, 5, 5).Text = "fvalue"
            Dim fbold As Font
            fbold = New Font("Comic Sans MS", 10, FontStyle.Bold)
            Dim fitalic As Font
            fitalic = New Font("Comic Sans MS", 10, FontStyle.Italic)
            Dim funderline As Font
            funderline = New Font("Comic Sans MS", 10, FontStyle.Underline)
            FpSpread1.Sheets(0).Cells(1, 1, 5, 5).Font = fbold
            FpSpread1.Sheets(0).Cells(1, 1, 5, 5).Font = fitalic
            FpSpread1.Sheets(0).Cells(1, 1, 5, 5).Font = funderline
     I hope it will help you.
    Thanks DeepakSharma, foy quick reply
     RB Indifferent
    RB,
    You can OR the FontStyles together you want for the new Font object.
    rangeFont = New Font(defFont, FontStyle.Bold Or FontStyle.Italic Or FontStyle.Underline)
    Thanks scotts
    Work fine
     Thanks a lot
    RB
  • Posted 30 October 2018, 6:59 am EST
    Hi team,
    could you please help me to set multiple format on the group of cell by using angular.
    and then want to increase font size of selected group range.
    e.g. I want to set range(2,3,6,7) of cells data as bold and italic.
    and under line works fine for me. by using below code
    var selectedRanges = this.sheet.getSelections()[0];
        this.sheet.getRange(selectedRanges.row, selectedRanges.col, selectedRanges.rowCount, selectedRanges.colCount, GC.Spread.Sheets.SheetArea.viewport).textDecoration(GC.Spread.Sheets.TextDecorationType.underline);
    Note : when we increase font size with selected range then it remove bold/Italic format from cell.
    Manoj
