Setting some properties of each cell is too slow in 14.45.20213.0 version
Posted by: lee.hs on 16 April 2022, 3:21 am EST
  • Posted 16 April 2022, 3:21 am EST
    We had upgraded Farpoint Spread to 14.45.20213.0 from 4.0.3512.2008 in this year.
    With same cases, their are such a massive gap in performance between them.
    Example)
    Conditions : 103 Columns / 430 rows
    Setting BackColor for each cell takes 00:00:00.0000020~30 in old ver.
    Setting BackColor for each cell takes about 00:00:00.0001021~33025 in new ver.
    Setting Renderer, NoteIndicatorColor are seriously slow too.
    It seems more data take more times for setting each cell`s properties.
    Could you guide us what makes these get so much slower than old ver.?
    Lee
  • Posted 18 April 2022, 2:00 am EST
    Hi Lee,
    Could you please share a small sample replicating how you are setting the properties for these cells? We check for a range of 103 columns and 430 rows and got similar results in both versions. Please share a sample so that we can investigate further at our end.
    Avnish
  • Posted 18 April 2022, 10:54 pm EST
    Hi Avnish,
    Thanks for your reply.
    I made a sample and uploaded to the link below.
    https://drive.google.com/file/d/1LpTTtn76dI5jb2wNldJQOYs8F71TfYeB/view?usp=sharing
    The sample looks quite messy(sorry), but only you need to see is
    [TSpreadGrid.cs - line 288]
    cell.Renderer = renderer as IRenderer;
    During make this sample, we figured out that setting [cell.Renderer] makes all these performance gaps.
    Here is the steps.
    1. Run this sample.
    2. Maximize the Winform.
    3. Do auto sorting with the [InVoy] column twice.
    4. See the performance and output prompt logs.(There is time elapse for setting cell`s fore/back colors.)
    Guide video is here.
    https://drive.google.com/file/d/1Q9CHEa9MGTnPPpp-A9juEf0QdWkWu-rl/view?usp=sharing
    When you delete [TSpreadGrid.cs - line 288], you would see it much get faster.
    Our [CodeRenderer] do nothing further in here, and even while do something, it was not a problem with old ver.
    I hope it would be helpful.
    Lee
  • Posted 18 April 2022, 11:33 pm EST
    Hi Lee,
    We could not access the files using the links you provided. We have created a case on our support portal [Case ID: CAS-30669-K8R8S1]. Please continue the thread there.
    You can find your support cases in the “My Support” section of your grapecity account.
    Link: https://www.grapecity.com/my-account/my-support
    Avnish
