Spread 9.35.20.... fails to open an Excel file
Posted by: info on 22 March 2018, 3:51 am EST
    Posted 22 March 2018, 3:51 am EST
    Spread can’t open the attached file.
    Can we setup Spread in a way that it will always open such a file? Or is this a bug?
    Thanks in advance,
    Piet
  • Posted 23 March 2018, 2:24 am EST
    Hi Piet,
    It seems the file could not be attached. Please try again and make sure you are attaching a zip file less than 5MB in size.
    Deepak Sharma
  • Posted 23 March 2018, 10:45 am EST
    de hoop pekso.zip
    Hope this helps
    -Piet
  • Posted 26 March 2018, 11:19 am EST - Updated 30 September 2022, 2:19 pm EST
    Hi Piet,
    I tested this file with Spread latest version i.e. v11.0. and seems to be opening without any issues. Please refer to the attached image. I would suggest you to please upgrade to the latest version.
    Deepak Sharma
  • Posted 27 March 2018, 5:58 am EST
    Hi Deepak,
    from the past I now there is a lot of testing required regarding changes in using CTRL-C and CTRL-V and so on.
    So this is will be my last resort.
    Did you test in 9.35? and if it would not open is there a workaround?
    Kind regards,
    Piet
  • Posted 28 March 2018, 6:04 am EST
    Hi Piet,
    I tested this with Spread v9.35 and could see that the file is not imported properly.
    However it looks that the issue is fixed in our latest version, so I suggest to upgrade to get rid of the issue.
    Deepak Sharma
