Spread Net Version 15
Posted by: stephane.chabeau on 24 November 2021, 1:19 pm EST
  • Posted 24 November 2021, 1:19 pm EST
    I
    I downloaded the “Spread.NET + Installer.exe” file to test version 15 with Visual Studio 2022
    This program cannot be started.
    An area appears then immediately disappears without explanation.
    I have tried on 2 PCs with the same result.
    Do you have any idea about this problem?
    Thank you
    Stephane
  • Posted 28 November 2021, 11:39 pm EST
    We have reported the issue to the dev team and will let you know when we have an update. In the meantime, you can use Spread 15 in your project by using the Nuget package.
    Nuget: https://www.nuget.org/packages/GrapeCity.Spread.WinForms/
    [Internal Tracking ID: SPNET-21824]
    Avnish
  • Posted 3 December 2021, 1:09 am EST
    Could you please let us know what is the RegionalFormat set in your window’s region settings?
    In the meantime, as a workaround, you can use the installer after setting the RegionalFormat to English(US) and it should work.
    Avnish
  • Posted 15 December 2021, 5:30 am EST
    The issue has been fixed, please download and use the latest installer from https://cdn.grapecity.com/SpreadNET/installer/current/Spread.NET+Installer.exe.
    Avnish
  • Posted 16 December 2021, 12:54 pm EST
    Hi
    Yes, it works well now…
    Thank you
    Stephane
