Posted 1 February 2018, 7:58 am EST
Hi !
When I select Spead Sheet Merge Cell, I like to display it as attached image.
I look for a solution.
thank you.
Forums Home / Spread / Spread for WinForms
Posted by: addio777 on 1 February 2018, 7:58 am EST
Hi !
thank you.
Posted 6 February 2018, 7:13 am EST
Thanks for the reply.
There is one more question. MergePolicy.Restricted
I want to select only merged cells.
Posted 7 February 2018, 5:28 am EST
Please refer the modified code as per your requirement.
private void FpSpread1_SelectionChanged(object sender, FarPoint.Win.Spread.SelectionChangedEventArgs e)
int top_test=0, bottom_test=0;
int top_Row = e.Range.Row-1, bottom_Row = e.Range.Row+1 ;
while (top_Row >= 0 && FpSpread1.ActiveSheet.Cells[top_Row, e.Range.Column].Value.ToString() == FpSpread1.ActiveSheet.Cells[e.Range.Row, e.Range.Column].Value.ToString()&& top_test == 0)
for (int i = e.Range.Column; i >= 0; i--)
if (FpSpread1.ActiveSheet.Cells[top_Row, i].Value.ToString() != FpSpread1.ActiveSheet.Cells[e.Range.Row, i].Value.ToString())
top_test = 1;
break;
else
top_test = 0;
if (top_test == 0)
top_Row = top_Row - 1;
while (bottom_Row < FpSpread1.ActiveSheet.RowCount && FpSpread1.ActiveSheet.Cells[bottom_Row, e.Range.Column].Value.ToString() == FpSpread1.ActiveSheet.Cells[e.Range.Row, e.Range.Column].Value.ToString() && bottom_test == 0)
if (FpSpread1.ActiveSheet.Cells[bottom_Row, i].Value.ToString() != FpSpread1.ActiveSheet.Cells[e.Range.Row, i].Value.ToString())
bottom_test = 1;
break;
else
bottom_test = 0;
if (bottom_test == 0)
bottom_Row = bottom_Row + 1;
FpSpread1.ActiveSheet.AddSelection(top_Row+1, e.Range.Column, bottom_Row - top_Row-1, 1);
Also, refer the attached sample.
Prj_CellSpan_modfied.zip
Posted 7 February 2018, 5:30 am EST
I am assuming that you are using automatic merging feature of spread. It is designed behaviour of spread that Merged cells do not lose their data; it is simply hidden by the merge. You can edit a cell that is merged with another cell. However, you can manually change the selection in “SelectionChanged” event. Please refer the following code:
while(top_Row >= 0&&FpSpread1.ActiveSheet.Cells[top_Row,e.Range.Column].Value.ToString() == FpSpread1.ActiveSheet.Cells[e.Range.Row,e.Range.Column].Value.ToString())
while (bottom_Row < FpSpread1.ActiveSheet.RowCount && FpSpread1.ActiveSheet.Cells[bottom_Row, e.Range.Column].Value.ToString() == FpSpread1.ActiveSheet.Cells[e.Range.Row, e.Range.Column].Value.ToString() )
Also, refer the attached sample for implmenting the same.
If our assumption is incorrect. Kindly explain your requirement in more details
Prj_CellSpan.zip
