Spread Studio 9.0.20153.0 Combobox Selection Bug
Posted by: Jahan_Zaib_Akhtar on 28 March 2018, 2:47 am EST
    Posted 28 March 2018, 2:47 am EST
    Hi, I am usnig VS 2017 Winforms vb.net.
    I discovered a very strange behavior and need a solution.
    I have meanwhile tested different possibilities, with runtime code or even with Spread designer.
    Problem is, that when the Combobox cell is empty, I am able to select a value from the dropdown.
    BUT when the cell has already a value, I can dropdown the Combobox, and click it, but It doesn’t take my selected value, so the cell value stays as it was before.
    Please help.
    Thank you
  • Posted 28 March 2018, 6:09 am EST
    I am not able to replicate this issue with the latest release of Spread v9.0 i.e. v9.20.20161.0. Please download the build from here and test the installed sample.
    http://cdn.grapecity.com/SpreadStudio/9.0.20161.0/SpreadInstaller_9.0.20161.0.exe
    Let me know in case the issue still persists.
    Deepak Sharma
  • Posted 28 March 2018, 6:55 am EST
    Hi Deepak,
    thank you for the quick responce.
    I found out that the problem was not the Spread version, it is the Metro Modern Ui Framework, what I am usnig in my Project.
  • Posted 28 March 2018, 9:54 am EST
    If someone knows any workaround for this problem please share.
    This problem only appears when a Form has setup MetroFramework.
  • Posted 9 April 2018, 3:00 am EST
    Thanks for letting us know. In case you face any issues with Spread control please feel free to get back to us.
    Deepak Sharma
