Posted 27 August 2019, 4:04 am EST
I am having a problem with the methods of recalculation on the SheetView class.
These methods are described as allowing the cells to be reevaluated and customFormules that have changed (or not with recalculateAll) on the sheet since the last recalculation cycle .
But when I call it after my file opening in a loop on Spread.Sheets, I realize that every sheet of my workbook is reevaluated, even those that are invisible.
Is there anything I do not understand or is there a problem whith this method?
var fpSpread = new Fpspread();
fpSpread.OpenExcel(Path);
// Add a customFormula to debug Evaluate
// Put this custom formula in the last sheet
foreach (SheetView sheetView in fpSpread .Sheets)
sheet.Recalculate();
Thanks for your help.
Best regards.
