Spred.NET 15 for winform, using DefaultSheetDataModel on Linux machine
Posted by: lab on 11 October 2022, 9:03 am EST
    Posted 11 October 2022, 9:03 am EST
    i’ve seen on your website that the version 15 of Spread.NET for winform is also avaiable via NuGet with a package built with .NET6.
    I was wondering if it’s possible to run the DefaultSheetDataModel on Linux machine, i mean just the data model without all the visual objects, just to execute formulas in a sheet built at runtime.
    regards
  • Posted 12 October 2022, 3:21 am EST
    As we understand, you want to perform processing on Excel files on Linux using only the API and not UI. You can not use Spread.NET for Winforms as it uses windows specific APIs, you can use our Documents for Excel .NET API https://www.grapecity.com/documents-api-excel that supports this.
    If you have any questions, please let us know.
    Avnish
  • Posted 12 October 2022, 8:44 am EST
    yes you got the point, thank you for the answer
    regards
  • Posted 8 November 2022, 2:26 am EST
    I figured out the problem after reading this question and answer
    @drift boss
