Timer error when creating fpspread component
Posted by: tosch on 9 December 2020, 8:52 am EST
  • Posted 9 December 2020, 8:52 am EST
    I have a library where I use fpspread to load some data.
    On then line
    m_fpspread = new FpSpread
    this exception is thrown:
    The value 0 for interval is invalid. Interval must be greater than 0
    Stacktrace:
    at System.Windows.Forms.Timer.set_Interval(Int32 value)
    at FarPoint.Win.Spread.FpSpread…ctor()
    at s3_OfficeOutput.cOrder.LoadOfficeDocument(String Filename, String DocumentID, String Username) ← my component
    Is a timer used when creating a spread component?
    I have no clue why this exception is thrown.
    The same code works fine on a different machine.
    Using version 11.45.20183.0
    Thomas
  • Posted 10 December 2020, 6:33 pm EST
    Hello Thomas,
    I have not come across this exception, specially the stack trace with Timer so, this is strange.
    1. Is this exception occurring in a new application, with only FpSpread?
    2. >The same code works fine on a different machine.
      Are you having the same Spread.Net version installed on the other machine?
    3. Spread v11 is now no more in development and hence, its support is not available. So, you are suggested to install the latest Spread version on the machine you are facing the exception and see, if you still get the exception?
