Two diagonal red lines across the grid
Posted by: parez81-fp on 8 September 2017, 1:16 pm EST
  • Posted 8 September 2017, 1:16 pm EST
    Sometime I get two diagonal red lines across the grid and it makes it unusable.It doesnt happen often.But when it does i have to close the form and open again.And if i run the same request again(same input for the grid) it works next time.
    It is accompanied by index out of bound error. Is this is a known problem?
    I will attach a screenshot next time that happens and more details.
    This probably could be something on my end but i just wanted to make sure that its not a bug.
    I used to see this occassionally when something was not getting serialized correctly or the references were mixed up but I haven’t seen it in years.  What version are you using?
    This would happen any time there is an exception in the paint code. This is possible to be a bug, but as Bob stated, we have fixed any bugs we are aware of. Make sure you are using the latest release. If you are, could you post a small zipped project reproducing the issue for us to debug?
    This error is accompanied by  “Invalid row index: 0 ( must be -1 and -1)” error.
    I dont know where the error  occurs. I have set up a conditional break point so that i debug it.
    my version number is 4.0.2001.2005.  winforms 3.0  c# on VS2008.
    There is no definite way of replicating the error.The application makes a TCP/IP requests and sends xml messages to the server which is behind firewall. I mite not  be able to give you access to the app.
    I mananged to get stacktrace
       at FarPoint.Win.Spread.FpSpread.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    Have you tried getting version 4.0.2003 to see if that solves the problem?  I have never seen this issue in any release of version 4.
    In addition to what Bob stated, are you making calls on a seperate thread to change information on the Spread like RowCount etc.?
    Yea… I am using a separate thread to popuate the grid.
    you think that could be the problem? I started seeing more of this problem after i implemented the async populatation of the grid but i cannot say for sure i had not seen it before.
    I just now changed the code to
    fpSpread1.Invoke((MethodInvoker)delegate() { fpSpread1.ActiveSheet.Models.Data = new FarPoint.Win.Spread.Model.DefaultSheetDataModel(value, typeof(FinancialDataSummaryItem)); });
    that will make the ui thread to populate the grid.
    I will keep you posted.
    I believe this is the cause of the issue. Running the seperate thread on a delegate call should fix the issue. If it does not, could you post a small zipped project reproducing this issue for us to debug?
    Its been good so far… its not crashed after i made the changes.I will get back to you guys if it happens again…
    Thanks for letting us know.
     I'm curious what is acceptable to access/modify outside of the main thread and what is not?
    Really nothing is acceptable to access/modify in a seperate thread unless you invoke the call through a delegate.
    Dear Support,
    I am facing similar issue and i am getting this exception before getting Red X.
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Exception: Exception handled in FpSpread.WndProc ---> System.Exception: Exception handled in FpSpread.OnPaint() ---> System.NullReferenceException: Object reference not set to an instance of an object.
       at FarPoint.Win.Spread.SpreadView.e(Graphics A_0)
       at FarPoint.Win.Spread.SpreadView.g(Graphics A_0)
       at FarPoint.Win.Spread.FpSpread.OnPaint(PaintEventArgs e)
       --- End of inner exception stack trace ---
       at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
       at System.Windows.Forms.Control.WmPaint(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
        CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    I am working on a real time application and my grid needs to updates asynchronously since GUI may get freezed at times. It works in sync way like the GUI thread fetching data from database and then binding to grid. But my requirement is that i want to bind data asynchronously to grid.
    I am using C#.Net 2005,spwin4_net20-2009, SQL Lite 3.0. Attaching my code snippet for your reference. Expecting good support from you as always. Please revert if you have code snippet for async binding
            private void cmdRefresh_Click(object sender, EventArgs e)
                fpBuy.ShowCell(0, 0, 0, 0, FarPoint.Win.Spread.VerticalPosition.Top, FarPoint.Win.Spread.HorizontalPosition.Left);
                fpSell.ShowCell(0, 0, 0, 0, FarPoint.Win.Spread.VerticalPosition.Top, FarPoint.Win.Spread.HorizontalPosition.Left);
                cmdRefresh.Enabled = false;
                lblErrMsg.Text = "Loading Data...";
                string errMsg = string.Empty;
                Debug.WriteLine("Refresh on PendingOrder Before PopulatePendingOrder");
                    GetPendingOrders work = new GetPendingOrders(PopulatePendingOrder);
                    AsyncCallback CompleteCallBack = new AsyncCallback(ShwPendngOrder);
                    work.BeginInvoke(ref mobjQuery, ref errMsg, CompleteCallBack, null);
                Debug.WriteLine("Refresh on PendingOrder call completed PopulatePendingOrder");
            public Boolean PopulatePendingOrder(ref clsClientQueries objQuery, ref string msg)
                msg = "";
                try
                    Debug.WriteLine("Entry PopulatePendingOrders");
                    mobjQuery = objQuery;
                    mobjQuery.GetPartQueries();
                    if (mobjQuery.BuySellInd == clsConstantsEnums.gstrConstBuy)
                        //only buy
                        mobjQuery.ShowResults(mobjQuery.BuySellInd);
                    else if (mobjQuery.BuySellInd == clsConstantsEnums.gstrConstSell)
                        //only sell
                    else
                        mobjQuery.ShowResults(clsConstantsEnums.gstrConstBuy);
                        mobjQuery.ShowResults(clsConstantsEnums.gstrConstSell);
                    Debug.WriteLine("exitting PopulatePendingOrders");
                    if (mobjQuery.BuyPendOrd.Count == 0 && mobjQuery.SellPendOrd.Count == 0)
                        msg = "No Data Found";
                        return false;
                    else
                        return true;
                catch (Exception ex)
                    clsBALCommon.gobjclsFunction.LogInformation(clsConstantsEnums.EnumLogFOR.LOGTWS, "frmPendingOrders-PopulatePendingOrder", string.Empty, ex, string.Empty, clsConstantsEnums.EnumCriticality.Critical, clsConstantsEnums.EnumRespOutputColor.Red, string.Empty, clsConstantsEnums.EnumRequestType.EXCEPTION);
                    throw ex;
            public void ShwPendngOrder(IAsyncResult result)
                string msg = "";
                Debug.WriteLine("Callback completed PopulatePendingTrades");
                AsyncResult ar = (AsyncResult)result;
                GetPendingOrders work = (GetPendingOrders)ar.AsyncDelegate;
                Boolean isSuccessful = work.EndInvoke(ref mobjQuery, ref msg, result);
                isSucessFull(isSuccessful, msg);
            public delegate void delNoDataFound(bool isVal, string msg);
            public void isSucessFull(bool isVal, string msg)
                if (isVal == true)
                    OpenPendingOrder();
                else
                    if (this.InvokeRequired)
                        this.Invoke(new delNoDataFound(isSucessFull), isVal, msg);
                        return;
                    //this.lblError.Text = msg;
                    this.lblErrMsg.Text = msg;
                cmdRefresh.Enabled = true;
            public delegate void delOpenPendingOrder();
            public void OpenPendingOrder()
                    this.Invoke(new delOpenPendingOrder(OpenPendingOrder));
                    return;
                Debug.WriteLine("showing PendingOrder");
                this.lblErrMsg.Text = string.Empty;
                //InitializePendOrder();
                ShowPendingOrder();
                //gobjPendingOrder.Show();
                //this.Hide();
                //frmClientQueryClosing();
    Sanket
    I was not able to make out from your code what approach are you actually following to perform the update to th database. It would be a great help if you could provide me with a sample that depicts your approach and the exception that you are getting, so that I could look into the issue further.
    Manpreet Kaur.
    The Exception I am getting..
    mscorlib
     I will Explain where the datatable gets updated which is bound to datasource of farpoint spread.
                    GetPendingOrders work = new GetPendingOrders(PopulatePendingOrder);      //async call has been done through delegete GetPendingOrders
                    AsyncCallback CompleteCallBack = new AsyncCallback(ShwPendngOrder);  //async call has been done through ShwPendngOrder
           //In this Function PopulatePendingOrder, Datatable gets updated bound to datasource of farpoint spread
                msg = "";
                try
                        //only buy
                        //only sell
                    else
                        return false;
                    else
                        return true;
                    throw ex;
    //This is async call back...in which EndInvoke returns if datatable gets updated successfully or not..if successful open the following form else dont ope nthe form
                string msg = "";
                if (isVal == true)
                    OpenPendingOrder();
                else
                        return;
                    return;
                ShowPendingOrder();
                //this.Hide();
    I was not able to debug the issue reported by you, from the code provided by you. I would need the complete sample to debug your issue and help you out further. I would also suggest you to update to the latest version of Spread v4.0.2026, try executing your application with the latest version,  and check out if it resolves your issue. Please let me know your observations. You can find the latest version of Spread v4.0.2026 at the following link:
        ftp://ftp.fpoint.com/SpreadWinForms4/
    Manpreet Kaur.
    Hi
    I have downloaded the latest version of Farpoint from the link you gave.But the problem persists.Same red X is displayed on spread if I go on refreshing the the farpoint spread.
    As I have used asynchronous delegate in my project,the query is run on the separate thread and when it is executed sucessfully,the callbak function is called.In that callback function datatable  is again bound to spread .For that purpose we have usesd Asynchrous Helper Class from codeproject.You can find it here:
    http://www.codeproject.com/KB/threads/Asynchronousity.aspx
    We have used Async OI call on UI from this project.
    I went through the link provided by you and I was able to get an overview of the approach you are following. But I would need a sample depicting the issue that you are facing to assist you further with the same. Please provide me with a sample.
    Manpreet Kaur.
  • Posted 25 June 2018, 5:52 am EST
    I have got red cross again in production executable after using the latest version 11 of spread.
    Can scotts-fp tell what fix need to be put in code. We are using all delegate to ensure there no other thread updating the spread
