Unable to resize column widths
Posted by: grapecity on 2 August 2018, 1:50 pm EST
    Posted 2 August 2018, 1:50 pm EST
    In my application I have column resizing properties set to True. When I create a new .xml file with a single sheet I can run the application and I can resize the columns. And I can save and reopen the file and am still able to resize the columns. While running the application I can add another sheet and am still able to resize the columns.
    However, if I then save the file with the additional sheet and then reopen the .xml file in the application I can no longer resize the columns in the application.
    Additionally, when I open that .xml file in the Designer I can not longer select a column by clicking on the column header.
    Do you have any ideas?
    Thanks, Ed
  • Posted 3 August 2018, 3:14 am EST
    Hi Ed,
    I am not able to replicate this issue at my end. Please refer to the attached XML file. I opened this workbook with 2 sheets with Spread Designer and was able to resize the columns.
    Please make sure that your sheet is not protected/locked.
    Deepak Sharma SpreadWinColumnResize.zip
  • Posted 8 August 2018, 12:47 pm EST
    Hi Deepak,
    I don’t think I have any code that is locking the sheet. Attached is a sample of a file (A4.xml) created in our application. If you open the file in the designer and try to select a column by clicking on the column header you will see that you can’t select a column. Before I added the second sheet and saved the file I could resize the columns in both my application and when I went into the designer I could select a column.
    Thanks, Ed
  • Posted 9 August 2018, 4:59 am EST
    Hi Ed,
    It seems that the attachment could not get through. Please resend it.
    Deepak Sharma
  • Posted 20 August 2018, 1:48 pm EST
    Hi Deepak,
    Sorry for the delay.
    A4.zip
  • Posted 22 August 2018, 7:43 am EST - Updated 30 September 2022, 2:11 pm EST
    I am unable to replicate this issue at my end with Spread Win v11.45.20181.0.
    Please refer to the attached image which shows the selected column and also resizing bar.
    Deepak Sharma
  • Posted 4 September 2018, 2:58 pm EST
    Thanks. I will check to make sure I have the latest build.
  • Posted 5 September 2018, 1:39 am EST
    Hi Ed,
    Sure, let me know in case the issue still persists.
    Deepak Sharma
