Posted 6 February 2019, 3:36 pm EST
We are running a VS2017 application (.Net framework 4.6) using Spread V9.35. We upgrade the Spread for WinForms to V12.45. I updated the references in the application (VB.Net) and updated the licenses.licx to use 12.45. When I try to compile the application, I’m getting lots of errors (about 7,000). But the error that seems to possibly be the root cause is this: error BC30652: Reference required to assembly ‘GrapeCity.Spreadsheet.Win, Version=12.45.20181.0, Culture=neutral, PublicKeyToken=327c3516b1b18457’ containing the type ‘BaseStyleInfo’. Add one to your project.
Our references to the spread are prefaced with FarPoint (like Farpoint.win). But I decided I would just add the reference in the error message and rebuild. Some Progress, I’m down to 4500 errors. Most of them are a variation of this:
error BC30456: ‘ForeColor’ is not a member of ‘EnhancedColumnHeaderRenderer’.
error BC30456: ‘RightToLeft’ is not a member of ‘EnhancedColumnHeaderRenderer’.
I think I’m missing something fundamental. I can’t find much on upgrading other than update the references and change the licenses.licx file.
Can you provide any assistance?
Sally
