User resizing columns on protected spread sheet
Posted by: david.sheppard on 13 April 2023, 4:37 pm EST
    Posted 13 April 2023, 4:37 pm EST
    When I set protect = true, users cannot resize the columns. I want users to be able to resize columns when I have protect=true on the sheet.
    Is this possible?
  • Posted 14 April 2023, 1:13 am EST
    Hello David,
    You can use the Protect method of the SheetView class excluding the FormatColumns option to allow the user to resize the columns.
    fpSpread1.AsWorkbook().ActiveSheet.Protect(WorksheetLocks.All & ~WorksheetLocks.FormatColumns);
  • Posted 14 April 2023, 6:08 am EST
    Thank you for your fast response.
    Your recommendation worked, but I had to add a NOT operator before the FormatColumns
    Fpspread1.AsWorkbook().ActiveSheet.Protect(GrapeCity.Spreadsheet.WorksheetLocks.All And NOT(GrapeCity.Spreadsheet.WorksheetLocks.FormatColumns))
  • Posted 16 April 2023, 10:50 pm EST
    Yes, you are right because the code we have given you is in C# and if you are using VB.net, you need to use the NOT operator.
