Visual Studio 2019 Problem
Posted by: peter.herschel on 24 July 2019, 2:20 pm EST
    Posted 24 July 2019, 2:20 pm EST
    I am experience a problem with the form designer. When I change the names of variables in the designer UI, they revert back when the project is closed and reopened.
    DETAILS:
    Visual Studio: 2019 v16.1.6
    SpreadNet 12.45.20181.0
    Create a winform project. Target Net framework 4.7.2
    Drag the spread control from toolbox on to form.
    The variable fpSpread1_Sheet1 is created below the form.
    Click on the spread control, go to properties and in the design section change the name of the control:
    Changed from fpSpread1 to fpSpreadXX
    The do you want to rename the spreadview objects dialog appears. Click on yes.
    The variable at the bottom of the form is renamed fpSpreadXX_Sheet1
    Save the form and close the project, then reopen it and reopen the form.
    The name of the variable at the bottom of the form is back to fpSpread1_Sheet1. Browsing the sheets collection in properties for the spreadnet control has the the name changed back to fpSpread1_Sheet1.
    Is there a version of the SpreadNet that works with Visual Studio 2019 UI designer? Maybe I have the wrong version?
    -Pete
  • Posted 25 July 2019, 4:15 am EST
    There is some issue related to designer had been fixed in the latest version of Spread.
    While working in Spread WinForms Designer, no exceptions of Designer Loader are thrown for any changes done and saved in the spreadsheets. [269697]
    When some settings like BackColor, CellType etc. are applied on a column using Spread Designer, the column settings can now be preserved and these settings do not disappear from Form’s designer after the Visual Studio application is restarted. [272312]
    Could you please recheck with the latest installer of Spread. You can download the same from the following link:
    https://www.grapecity.com/download/spreadnet
  • Posted 25 July 2019, 8:54 am EST
    I uninstalled and reinstalled. Version is now 12.45.20191.0 This version has fixed my problem! Thank goodness! I rely on this awesome control for so much of our custom financial software. Thanks for your help!
