Application crash when Formula is set to =TODAY()
Posted by: Jose.Aguirre on 19 October 2022, 5:19 am EST
    Posted 19 October 2022, 5:19 am EST - Updated 19 October 2022, 5:33 am EST
    when trying to set the formula =TODAY() to cell, it causes the application to crash. No exception nor another message to check what failed.
    Used version: 15.2.20223.0
                Cell cell = c.ActiveSheet.ActiveCell;
                //cell.Formula = "=SUM(A1:B1)";
                cell.Formula = "=TODAY()";
    It also crashes in the Spread WPF Explorer. Please fix.
  • Posted 19 October 2022, 8:04 am EST
    Hi Jose,
    Thanks for informing this behavior.
    We have replicate this issue at our end and we have escalated it to the development team. Will get back to you once we have any update from them.[Internal Tracking Id - SPNET-27489]
    Nitin
  • Posted 9 January 2023, 12:39 pm EST
    Hello, is this bug already fixed?
  • Posted 10 January 2023, 9:25 am EST
    Apologize for the inconvenience.
    As per the development team, This is a bug of the calculation engine. There’s an infinite loop in “Volatile” functions. It’s a known issue and not all volatile functions will be re-calculated when a cell value has changed.
    The original problem (application hangs) can be fixed in v16.1. The formula value update issue shadowed by the original problem is a limitation.
    So, you need to wait till v16.1 release.
    Nitin.
  • Posted 11 April 2023, 8:32 am EST
    Hello, where can I check your current version?
  • Posted 12 April 2023, 12:30 am EST - Updated 12 April 2023, 12:35 am EST
    Hi Jose,
    You can check with the latest installer. Select the latest version from the left-top dropdown. And then you can check the latest version specific to the technology i.e., Winforms, Asp.Net and WPF.
    You can download the latest installer from here: https://www.grapecity.com/spreadnet/download
    Nitin
