ColumnWidthChanged event gives wrong value of column width
Posted by: Jose.Aguirre on 24 August 2023, 2:52 am EST
    Posted 24 August 2023, 2:52 am EST
    when subscribed to the event:
    gcSpreadSheet.ColumnWidthChanged += OnGdmSpreadSheetColumnWidthChanged;
    a wrong value for the dragged column is returned.
    Steps:
    • create 2x2 sheet (columns A and B)
    • drag column A to the left as much as possible (behind the limits)
    • visually the width of column A seems to be 0 but when catching in the event above the value of:
    spreadSheet.ActiveSheet.Columns[e.ColumnList[0]].Width
    it is still the previous value.
  • Posted 25 August 2023, 5:17 am EST
    I think you meant for Resizing and not for dragging. Please correct if we are wrong.
    We have replicated this issue at our end while resizing a column to Zero width and it still taking the previous one.
    This issue seems like a bug. So, we have escalated it to the development team. Will get back to you once we have any update from them.[Intearnal tracking Id - SPNET-32983]
    Nitin
  • Posted 25 August 2023, 6:59 am EST
    Yes, you are right. It happens when resizing.
  • Posted 28 August 2023, 2:26 am EST
    As per the development team, The current behavior of Column.Width is by design. Because the internal implementation of set column width doesn’t change the column width to 0 when the column parameter is 0.
    We recommend using the Column.ActualWidth property to get the correct column width.
    Try below code to achieve your requirement:
    spread.ActiveSheet.Columns[e.ColumnList[0]].ActualWidth
    Please refer the attached sample for the same: WpfSpreadDemo.zip
    Nitin
