Spreadsheet set Column width to value of double
Posted by: Jose.Aguirre on 15 August 2023, 3:34 am EST
    Posted 15 August 2023, 3:34 am EST - Updated 15 August 2023, 4:03 am EST
    when I try to set the width (height) of the spreadsheet to some value, it sets only the integer part of the value, even if it is of type double:
    double GrapeCity.Windows.SpreadSheet.Data.Column.Width
    E.g.: Width = 135.666
    the result Width is 135
    How to set the double value properly? Even a pixel can not be half, so why a double…
  • Posted 16 August 2023, 3:56 am EST
    We are unable to replicate this behavior at our end. Width/Height are type of Double. If we set Width/Height = 135.666, then the Height/Width will be 135.666 not 135.
    Please refer the sample for the same: WpfSpreadDemo.zip
    Nitin
  • Posted 16 August 2023, 6:33 am EST
    Sorry, partially my mistake. But as also stated later, I meant:
    it means the width of the column
  • Posted 17 August 2023, 3:30 am EST
    Apologize for the inconvenience. We have replicated this issue at our end. This seems like a bug. So, we have escalated it to the development team. Will get back to you once we have any update from them.[Internal Tracking Id - SPNET-32688]
    Bets Regards
    Nitin
  • Posted 21 August 2023, 1:31 am EST
    As per the development team, The current behavior is by design. Because there’s an explicit cast in GetColumnWidth that truncates the width value.
    It’s unsafe to change this behavior directly. Because it will break other features. We can only add a new API to get the exact column width.
    We will let you know once the new API to fetch the exact column width will be added.
    Nitin
  • Posted 20 December 2024, 3:21 am EST
    Apologize for the delay. The new API was added to get the correct Width of the Column in Spread 17: ExactWidth.
    Please refer the attached sample for the same: WpfSpreadDemo.zip
    Nitin
