Posted 3 April 2018, 8:27 am EST
I’m in the process of evaluating your product as a possible solution to converting a Visual Basic 6.0 that uses FPSpread application into a Visual basic 2017 WPF application. The VB 6.0 application addressed FPSpread columns/rows starting at 1, 1 (treating the header column and row as 0, 0). I’m considering SpreadNET 11.0 WPF as a possible solution and continue my 30-day evaluation. Is there a way to modify the starting index from 0, 0 to 1, 1? This will prevent modifications to other areas that use 1, 1 as a column/row starting index.
Thank you,
Luis Alvarez
