WPF compatibility with windows remoteapp
Posted by: tsato on 22 June 2022, 9:26 pm EST
    Posted 22 June 2022, 9:26 pm EST
    hey all
    we are using a program that is using Spread for WPF, currently our users are accesing the Application server via single RDP session.
    I wanted to change this so the users connect via RemoteApp.
    If i were to not change anything on the program side and just let the users use the current application via RemoteApp instead of the traditional RDP. Is it supported?
    tl;dr is Spread for WPF supported on Microsoft RemoteApp (RDS)?
  • Posted 22 June 2022, 10:15 pm EST
    forgot to add that we are using Spread for WPF 1.0J
  • Posted 23 June 2022, 6:02 am EST
    Application should work as you just needs to access the application remotely.
    In case you are facing any issues then please share the details.
    Nitin.
  • Posted 23 June 2022, 8:42 pm EST
    thank you for the reply
    is it supported on a remote app environment though? thats what i was wondering. if there is any matrix sheet that has supported environment (remoteApp and traditional RDS included) that would be wonderful
  • Posted 24 June 2022, 2:17 am EST
    Sorry but we are not clear about your requirement.
    Could you please confirm:
    Are you accessing the application(have Spread) remotely? or
    Are you using Spread in a remote app environment?
    Nitn.
  • Posted 24 June 2022, 2:42 am EST
    Hi nitin
    Currently we are using the application remotely.
    Windows Client > Application(with spread)
    In the future we want to use it via remoteapp
    Windows Client > RemoteApp > Application(with spread)
    regards
  • Posted 24 June 2022, 3:27 am EST
    It will work in this scenario unless you are changing anything in your application(spread).
    If you will face any issue, then please inform us with details. So, that we can investigate accordingly.
    Nitin.
  • Posted 24 June 2022, 4:36 am EST
    thank you very much, well probably test it out somewhere in the future and if any problem arise ill come back here for some help
    thanks!
  • Posted 11 May 2023, 6:52 am EST
    Is the problem solved
  • Posted 15 May 2023, 3:31 am EST
    Are you facing any issues while running Spread on Windows remote App?
    If you are facing any issues, then please inform us withe details like machine configuration Spread version, Remote App details etc. So, that we can investigate at our end.
    Nitin
