Change thousands and decimal separator - Angular spread sheet
Posted by: iteam on 9 July 2019, 4:43 am EST
    Posted 9 July 2019, 4:43 am EST - Updated 3 October 2022, 10:48 am EST
    Hi everyone.
    I’m trying to figure it out how to change cell formatting in angular wrapper of spread sheet.
    I’ve seen that changing globalization doesn’t suit my needs.
    If the standard numeric format is "4,294,967,295.00 ",
    I’m searching a way to make it like this “4.294.967.295,000”.
    I’m not very practice with spread sheet and Angular wrapper doesn’t publish all the options described on sheets documentation.
    Since I haven’t reached the goal to set globalization, I’ve tried to use gc-column formatting:
    <gc-column [headerText]="'Gennaio'"
                        [width]="75"
                        [formatter]="'#,##0'"
                        [dataField]="'Gennaio'">
    </gc-column>
    The result has “,” has thousands separator and “.” as decimal separator.
    Can you suggest me a way to invert separators? Or maybe give me an help how to use a custom formatter with Angular wrapper?
    Thanks in advance.
  • Posted 10 July 2019, 2:36 am EST
    To change the decimal and number separators, you need to add a custom culture with the specified settings:
    Please refer to the following code snippet and the attached sample demonstrating the same:
    let myCulture = new GC.Spread.Common.CultureInfo();
        myCulture.NumberFormat.numberDecimalSeparator = ",";
        myCulture.NumberFormat.numberGroupSeparator = ".";
        myCulture.NumberFormat.listSeparator = ";";
        myCulture.NumberFormat.arrayListSeparator = ",";
        //add one culture
        GC.Spread.Common.CultureManager.addCultureInfo("myCulture", myCulture);
        //switch to "myCulture" culture
        GC.Spread.Common.CultureManager.culture("myCulture");
    Please refer to the following document for more info regarding creating a custom culture: http://help.grapecity.com/spread/SpreadSheets12/webframe.html#culturecustom.html
    angular-culture-update.zip
  • Posted 10 July 2019, 3:25 am EST
    Works perfectly.
    For Angular developers like me, that have started programming with typescript instead of javascript, docs based on javascript ar not very clear.
    Solutions like yours should be putted in spreadJs angular docs in my opinion!
    Thanks a lot four you help!
    ps: I’m not saying that is your fault. A typescript developer should know javascript as well, but is not mandatory for using Angular!
  • Posted 11 July 2019, 12:05 am EST
    Thank you for your valuable feedback. We have forwarded your request for updating docs to the concerned team.
