Posted 30 October 2024, 4:54 am EST
- Updated 30 October 2024, 4:59 am EST
The observed behaviour is by design and is expected. When you copy/paste from the Cell A1 to Cell B4, by default the data validator of Cell A1 (which is undefined) will also be copied to the Cell B4 which will make the Cell B4 data validator as undefined and therefore, the data validator doesn’t circle the Cell Value on Cell B4.
This behaviour is same as that of Microsoft Excel. If you copy paste using the context menu, and paste only the values, you will see that it correctly highlights the invalid value on Cell B4. Refer to the following gif on using the context menu.
If you don’t want the data validator to be replaced, you can use any of the approach.
- Set the Clipboard Option to paste only the values: You could set the clipboard option to paste only the values. This way only the values will be pasted for each of the cells, and not conditional formatting, styles, data validators, etc. Note that it will work for each and every cells.
//This example uses the ClipboardPasteOptions enumeration.
activeSheet.options.clipBoardOptions = GC.Spread.Sheets.ClipboardPasteOptions.values;
Refer to the following clipboardOptions Docs: https://developer.mescius.com/spreadjs/docs/features/workbook/clipboard#site_main_content-doc-content_title
ClipboardPasteOptions Enumeration: https://developer.mescius.com/spreadjs/api/enums/GC.Spread.Sheets.ClipboardPasteOptions#values
- If you don’t want the behaviour for every cells, and only want that the validators should not get overridden when pasting the table cells, you could use the “ClipboardPasting” and “ClipboardPasted” events, and restore the data validators when the pasting is completed.
Refer to the following code snippet and the sample that demonstrates the same:
let oldTableValidator = null;
spread.bind(GC.Spread.Sheets.Events.ClipboardPasting, (sender, args) => {
console.log("Clipboard Pasting Event");
console.log(args);
let pastingCellRange = args.cellRange;
let isRangeInTable = checkCellRangeInTable(args.sheet, args.cellRange);
if (isRangeInTable) {
oldTableValidator = args.sheet.getRange(pastingCellRange.row, pastingCellRange.col, pastingCellRange.rowCount, pastingCellRange.colCount).validator();
} else {
spread.bind(GC.Spread.Sheets.Events.ClipboardPasted, (sender, args) => {
console.log("Clipboard Pasted Event");
console.log(args);
if (oldTableValidator) {
args.sheet.getRange(pastingCellRange.row, pastingCellRange.col, pastingCellRange.rowCount, pastingCellRange.colCount).validator(oldTableValidator)
Sample: https://jscodemine.mescius.io/share/kbmdjRks5UO6sWFNCPx19g/?defaultOpen={"OpenedFileName"%3A["%2Fapp.js"]%2C"ActiveFile"%3A"%2Fapp.js"}
References:
ClipboardPasting Event: https://developer.mescius.com/spreadjs/api/classes/GC.Spread.Sheets.Events#clipboardpasting
ClipboardPasted Event: https://developer.mescius.com/spreadjs/api/classes/GC.Spread.Sheets.Events#clipboardpasted
validator method: https://developer.mescius.com/spreadjs/api/classes/GC.Spread.Sheets.CellRange#validator
Let me know if you face any issues.
Ankit
