Dismissing the designer's File Menu after a custom button's action is executed
Posted by: eberridge on 17 April 2025, 12:01 pm EST
    Posted 17 April 2025, 12:01 pm EST
    Hello, I’ve been unable to figure out how to dismiss the designer’s File Menu after executing custom code associated with a button I added to the menu. In my scenario I add a custom “Export Excel” button directly to the menu under the default “Info” list item:
    const fileMenuPanelCommandName = DesignerGC.Spread.Sheets.Designer.CommandNames.FileMenuPanel;
    initializeDesignerTemplates
    Gets a copy of any default templates that need to be modified, modifies them, then
    registers the updated templates.
    Currently only needs to initialize the FileMenuPanelTemplate.
    export const initializeDesignerTemplates = () => {
      const fileMenu = DesignerGC.Spread.Sheets.Designer.getTemplate(
        DesignerGC.Spread.Sheets.Designer.TemplateNames.FileMenuPanelTemplate
      // Mescius documentation uses square bracket notation for template modifications,
      // apparently because type coersions cause the code to get too complicated.
      // To make this more robust we introduce some TypeScript types with type guards
      // in a targeted manner.
      // Effective root of sidebar (left) and panels (right)
      const root = fileMenu.content[0]['children'][0]['children'] as IColumnSetOption;
      // 1. Modify items from the side menu
      const menuList: (IListOption | ILabelLineOption | IButtonOption)[] = root[0].children[0].children;
      // 1e. Add Export Excel button to the bottom
      menuList.push({
        type: 'Button',
        margin: '10px 50px',
        text: 'Export Excel',
        width: 120,
        height: 120,
        bindingPath: 'button_custom_export_excel',
        iconPosition: 'top',
        iconClass: 'icon-common icon-excel'
      } as IButtonOption);
      const fileMenuCmd = DesignerGC.Spread.Sheets.Designer.getCommand(fileMenuPanelCommandName)!;
      const prevExecuteFn = fileMenuCmd.execute;
      fileMenuCmd.execute = (...args: [DesignerGC.Spread.Sheets.Designer.Designer, string, object]) => {
        // args is designer, propertyName, newValue
        const result = prevExecuteFn?.apply?.(fileMenuCmd, args);
        const [, propertyName] = args;
        if (propertyName === 'button_custom_export_excel') {
          handleExportExcel();
        return result;
      config.commandMap = {
        ...config.commandMap,
        fileMenuPanel: fileMenuCmd
      designer.setConfig(config);
      // Export Excel handler used by the Designer File Menu
      const handleExportExcel = useCallback(() => {
        if (!designer) return;
        const workbook = designer.getWorkbook() as Workbook;
        excelIO.save(
          JSON.stringify(workbook.toJSON()),
          (blob: Blob) => {
            saveAs(blob, 'myfilename.xlsx');
          ({ errorMessage }: { errorCode: ExcelIO.IO.ErrorCode; errorMessage: string }) => {
            notificationApi.error({
              message: 'Excel export error',
              description: `${errorMessage}`
      }, [designer, excelIO, notificationApi]);
    The button works, but it leaves me in the File Menu.
    I’ve tried doing this:
    designer.activeRibbonTab("home");
    That sets the ribbon tab to “home” but doesn’t dismiss the File Menu backstage view, so I can’t even see the tabs. The user must manually click the file menu’s “back” button to return to the ribbon.
  • Posted 17 April 2025, 6:59 pm EST
    For anyone with the same question, I figured it out. All you have to do is this:
    designer.setData('FileMenu_show', false);
    In a real-world scenario, the execute command’s args include the designer instance, which can be passed to your custom code.
  • Posted 20 April 2025, 11:20 pm EST
    You are right that setting the value of FileMenu_show to false will dismiss the Designer’s File Menu from the UI:
    designerInstance.setData('FileMenu_show', false);
    Ankit
