Error when using with Node.js: ReferenceError: canvas is not defined
Posted by: ken-sugiyama on 15 April 2024, 11:20 pm EST
    Posted 15 April 2024, 11:20 pm EST
    Hello.
    I’m trying to get SpreadJS to work with Node.js.
    I referred to the sample provided in the following topic and tried to start SpreadJS version 17.0.5.
    https://developer.mescius.com/forums/spreadjs/referenceerror-self-is-not-defined
    However, I encountered the following error:
    It seems to work with version 16.0.4. Do you have any idea what might be causing this error?
  • Posted 16 April 2024, 6:58 am EST
    The issue was caused because the Canvas was not defined. Refer to the below snippet to add canvas.
    const canvas = require("canvas");
    global.canvas = canvas;
    After adding the canvas, I encountered another error related to “Incorrect file format.” Upon investigation, I discovered that files were not importing correctly. Please refer to the following snippet to ensure files are imported correctly in a node environment.
    try {
    	var wb = new GC.Spread.Sheets.Workbook();
    	const data = fs.readFileSync('./export.sjs');
    	const blob = new Blob([data.buffer], { type: "application/zip" });
    	blob.name = "export.sjs";
    	blob.stream = fs.createReadStream('./export.sjs');
    	wb.open(blob, function () {
    		let sheet = wb.getActiveSheet();
    		console.log('-------load sjs file-------');
    		console.log(sheet.name());
    		console.log(sheet.getValue(3, 4));
    	}, function (e) {
    		console.log(e); // error callback
    		includeUnusedStyles: false
    	var wb1 = new GC.Spread.Sheets.Workbook();
    	const data1 = fs.readFileSync('./blank.xlsx');
    	const blob1 = new Blob([data1.buffer], { type: "application/vnd.openxmlformats-officedocument.spreadsheetml.sheet" });
    	blob1.name = "blank.xlsx";
    	blob1.stream = fs.createReadStream('blank.xlsx');
    	wb1.import(blob1, function () {
    		console.log('-------load excel file---------');
    		let sheet = wb1.getActiveSheet();
    		console.log(sheet.getArray(0, 0, 3, 1));
    	}, function (msg) {
    		console.log(msg); // error callback
    		fileType: GC.Spread.Sheets.FileType.excel,
    } catch (e) {
    	console.error("** Error manipulating spreadsheet **");
    	console.error(e);
    I have created a sample for reference.
    Sample: nodeJs_sjs.zip
    Priyam
  • Posted 16 April 2024, 9:51 pm EST
    Hi, thank you!
    I’ve resolved the error and can now use SpreadJS with Node.js.
    Eventually, I plan to load a JSON of SpreadJS and export it as an Excel file.
    I’ve written the following code:
    const fs = require('fs');
    const mockBrowser = require('mock-browser').mocks.MockBrowser;
    const fileReader = require('filereader');
    const { Blob } = require("buffer");
    global.window = mockBrowser.createWindow();
    global.document = window.document;
    global.navigator = window.navigator;
    global.self = global;
    global.HTMLCollection = window.HTMLCollection;
    global.getComputedStyle = window.getComputedStyle;
    global.FileReader = fileReader;
    const GC = require('@grapecity/spread-sheets');
    require('@grapecity/spread-sheets-io');
    const ExcelIO = require('@grapecity/spread-excelio');
    GC.Spread.Sheets.LicenseKey = "YourSpreadJSLicenseKeyHere";
    ExcelIO.LicenseKey = "YourExcelIOLicenseKeyHere";
    try {
        }, function (e) {
            const json = wb1.toJSON();
            const spread = new GC.Spread.Sheets.Workbook();
            const excelIo = new ExcelIO.IO();
            spread.fromJSON(json);
            console.log('-------export excel file from JSON---------');
            excelIo.save(
                spread.toJSON(),
                (blob) => {
                    fs.appendFileSync('./export-from-json.xlsx', Buffer.from(blob));
                (err) => {
                    logger.error(`Failed to output Excel file. ${err}`);
                { useArrayBuffer: true },
        }, function (msg) {
    } catch (e) {
        console.error(e);
    Excel file export succeeded. However, when blank.xlsx had images and text boxes pasted onto it, they were lost upon export. Do you have any idea what might be causing?
  • Posted 17 April 2024, 8:52 am EST
    We are still investigating the issue at our end. We will let you know about our findings as soon as possible.
    Priyam
  • Posted 18 April 2024, 3:04 am EST
    It seems like you haven’t imported the required dependencies in your application. Based on your code snippet that you have shared earlier, you are only using the following dependencies:
    However, in SpreadJS, the images are implemented as shapes and require you to add the shapes dependency in your application.
    Kindly try to add the following dependencies in your application:
    @grapecity/spread-sheets-shapes
    // For charts
    @grapecity/spread-sheets-charts
    Similarly, kindly add the required dependencies in your project.
    If the issue still persists for you, kindly do share a working sample along with the file that you are using so that we could investigate the issue at our end and could help you accordingly.
    Ankit
  • Posted 22 April 2024, 5:23 am EST
    I apologize for the delay in responding.
    Thank you for your kind instruction. I will try following them to see if it works.
  • Posted 22 April 2024, 11:50 pm EST
    Kindly try at your end with the solution provided above. If the issue still persists for you, kindly do share a working sample along with the file that you are using so that we could investigate the issue at our end and could help you accordingly.
    Ankit
  • Posted 24 April 2024, 10:43 pm EST
    I tried the solution you provided and confirmed that it works without any issues.
    Thank you for your kind support this time! It was very helpful.
  • Posted 11 July 2024, 6:57 am EST
    Hi there,
    const canvas = require(“canvas”) has fixed the issue - thank you for the suggestion.
    However, the dependency is very large and was not required for SJS v16. Is it possible to disable the feature that requires
    canvas
    If not, can you please confirm that .toJSON() and .fromJSON() in SJS v17 is backwards compatible with v16? This is not the case between v16 and v15, as v15 does cannot parse the sharedFormula elements.
    Many thanks
  • Posted 12 July 2024, 3:10 am EST
    SpreadJS v16 also requires a canvas to run properly. Please refer to the attached “Sample.zip”. In the sample, if you try to run the index file without a canvas, it will throw an error in version 16 as well.
    Sample: Sample.zip
    SpreadJS does not officially support Node.js; it is a workaround to use Node.js with SpreadJS. SpreadJS uses the canvas internally, so you will need to include the canvas, and there is no option to disable this feature to avoid this dependency.
    SpreadJS provides compatibility from v16 or v15 to v17 but not vice versa.
    Priyam
