Export frozen cells in HTML
Posted by: gustavo.quinalha on 8 December 2023, 3:11 pm EST
    Posted 8 December 2023, 3:11 pm EST
    Dear Mescius Team,
    I hope you are well. I would like to express my appreciation for the excellent work done with the tools offered by your company. I regularly use the features of your tables in my work and would like to suggest an addition that I consider valuable to further improve the user experience.
    Recently, I have been working with exporting data from tables to HTML and I have noticed that it would be extremely useful to have the tables exported including all generated properties, especially the freeze/hide columns property. This functionality would not only facilitate the table export process, but would also add significant value to the usability of the tables generated by your tools.
    Considering the quality and efficiency of the solutions provided by Mescius to date, I have confidence in the team’s ability to implement this improvement effectively while maintaining the high standards of performance and usability that characterize its products.
    I’m happy to discuss this suggestion in more detail if necessary, and I look forward to seeing the continued evolution of the tools offered by Mescius.
    Thank you in advance for your attention to this request.
    Yours sincerely,
    Gustavo Quinalha.
  • Posted 11 December 2023, 5:42 am EST
    Thanks for your appreciation.
    I did not understand your use case completely. As per my understanding, you want the hidden columns to be shown in the generated HTML of a cell range and the frozen lines should also be shown.
    Regarding the hidden columns to be shown in the generated HTML of a cell range, please note that the hidden columns are not shown in the HTML. This is by design.
    It is important to note that the frozen rows/frozen columns are sheet-level features and that is why the frozen lines are not shown in the exported HTML of a cell range.
    Kindly let us know if you still face the issue and if your use case is different. In that case, kindly explain your use case in more detail so that we can have a better understanding and help you accordingly. You may also use the attached sample to reproduce the issue/explain the use case.
    sample: https://jscodemine.grapecity.com/share/9toUCpQX_UmSugEX3dnhuQ/?IsEmbed=false&Theme=Unset&PreviewDirection=0&IsEditorShow=true&IsExplorerShow=true&IsPreviewShow=true&IsConsoleShow=true&IsRunBTNShow=false&IsResetBTNShow=false&IsOpenInCodemineBTNShow=false&PanelWidth=20&PanelWidth=50&PanelWidth=30&defaultOpen={"OpenedFileName"%3A["%2Findex.html"%2C"%2Fsrc%2Fapp.js"]%2C"ActiveFile"%3A"%2Fsrc%2Fapp.js"}
    Chandan
