Posted 4 January 2023, 2:14 am EST
We are sorry but there is no such method available to provide the plane argument string but functionToExpression returns the arguments object which has a property called type which is nothing but an ExpressionType enum. We could use it and create the arguments string. Please refer to the following code snippet which creates an argument string using ExpressionType number, function, and reference.
For the list of Expression Types you may refer to the following API:
Expression Type: https://www.grapecity.com/spreadjs/api/enums/GC.Spread.CalcEngine.ExpressionType
let str = "SUM(A1,AVERAGE(1,SUM(18,B1),C3),3)";
var expression = GC.Spread.Sheets.CalcEngine.formulaToExpression(
spread.getActiveSheet(),
str,
0,
0
let res = getStringFromArgs(expression.arguments);
function getStringFromArgs(argument) {
let res = [];
argument.forEach((arg) => {
let { type } = arg;
let sheet = spread.getActiveSheet();
switch (type) {
case GC.Spread.CalcEngine.ExpressionType.function:
res.push(
arg.functionName + "(" + getStringFromArgs(arg.arguments) + ")"
break;
case GC.Spread.CalcEngine.ExpressionType.number:
res.push(arg.originalValue);
break;
case GC.Spread.CalcEngine.ExpressionType.reference:
let str = GC.Spread.Sheets.CalcEngine.rangeToFormula(
new GC.Spread.Sheets.CellRange(sheet, arg.row, arg.column, 1, 1),
0,
0,
true
res.push(str.replace("$", ""));
break;
default:
break;
return res;
Avinash
