getPrecedents for range functions
Posted by: asaf.shechter on 14 March 2023, 10:46 am EST
    Posted 14 March 2023, 10:46 am EST - Updated 14 March 2023, 10:51 am EST
    I am trying to use the getPrecedents method for a cell that has a range in formula :
    and get only on cell back :
    there is another case when you have indirect function you also won’t get precedents at all , INDIRECT(“B2”) for example won’t return anything using the getPrecedents method…
  • Posted 16 March 2023, 1:54 pm EST
    This seems like a bug. So, we have escalated this issue to the development team. Will get back to you once we have any update from them.[Internal Tracking Id - DOCXLS-7791]
    Nitin
  • Posted 27 March 2023, 7:23 am EST
    meanwhile is there a possibility to bypass this bug?
  • Posted 28 March 2023, 7:37 am EST - Updated 28 March 2023, 7:42 am EST
    Apologize for the inconvenience.
    As per the development team. This is by design. The parameter of the Indirect function is text and not a reference. We can only do static analysis to formula when using Precedents method such as =SUM(A1:B2).
    You can check with MS Excel (see Image)
    Apologize, but no workaround is possible to achieve this.
    Nitin
  • Posted 28 March 2023, 11:31 am EST
    Ok good to know,
    and in case I want to get value of spilled formula in server side like UNIQUE(A1:A10) ,
    which method should I use?
    when using the getValue() method we get wrong result. (tried workbook.calculate() and still got result 0)
  • Posted 31 March 2023, 6:16 am EST
    Apologize for the delay.
    We are unable to replicate this issue at our end. Could you please provide a small Java sample to replicate this issue? So, that we can investigate and assist you accordingly.
    Nitin
  • Posted 3 April 2023, 6:41 am EST - Updated 3 April 2023, 6:47 am EST
    Hi ,
    as you can see at the attached images ,
    the result is spilled ,
    but when trying to get the value in server side I get only first value ,
    also excel file with the relevant example is attached.
    uniqueFunc.zip
  • Posted 4 April 2023, 7:04 am EST
    We are discussing this requirement with the development team. Will get back to you once we have any update from them.[Internal tracking Id -DOCXLS-7903]
    Nitin
  • Posted 6 April 2023, 12:14 am EST
    You can get all spilled values through below code:
    Workbook workbook = new Workbook();
    workbook.open("uniqueFunc.xlsx");
    Object[][] array =(Object[][])workbook.getWorksheets().get(0).getRange("B1#").getValue();
    for (Object[] row : array) {
        for (Object cell : row) {
            System.out.println(cell);
    Please refer the attached sample for the same: GCExcelSpill.zip
    Nitin
  • Posted 20 April 2023, 5:30 am EST
    Hi Nitin,
    your solution seems to do the trick for us,
    that’s what we were looking for ,
