IFilteredArgs Not Correct in gc.spread.sheets.d.ts
Posted by: Kevin.Happe on 12 January 2024, 3:37 pm EST
    Posted 12 January 2024, 3:37 pm EST
    I’m using V17 of the grid.
    HideRowFilters.onFilter method uses args:GC.Spread.Sheets.Filter.IFilteredArgs
    In the typedef file gc.spread.sheets.d.ts, IFilterArgs.columns property is defined as a number.
    However, when the onFilter method call is made the IFilterArgs.columns property is defined as number array
    So it seems the typedef file is wrong.
  • Posted 15 January 2024, 5:09 am EST
    Thanks for letting us know about the issue.
    We are able to replicate the issue at our end. Hence, we have escalated this issue to the concerned team for further investigation and resolution of the same. The internal tracking ID is SJS-22359 for this issue. We will keep you updated on the progress of the issue.
    Chandan
  • Posted 19 January 2024, 6:44 am EST
    The mentioned issue has been resolved in the latest release of SpreadJS which is SpreadJS v17.0.2. You may download the latest version of SpreadJS from the below link or through npm.
    Download link: http://cdn.mescius.com/spreadjs/17.0.2/Files/SpreadJS.Release.17.0.2.zip
