Increasing or decreasing multiple row or column width
Posted by: sbhadane on 23 July 2024, 8:32 am EST
  • Posted 23 July 2024, 8:32 am EST - Updated 23 July 2024, 8:40 am EST
    Possible bug in the current version of spreadjs.
    Steps to reproduce
    1. select more than 1 row/column
    2. Increase/Decrease the size
    Expected Behaviour: All the row/column width are increased
    Actual Behaviour: Only the last row/column width changes
    In the spreadjs v16.0.2 documentation it is working fine , but when tried in the developer mode ( designer ) it is not working as expected.
  • Posted 24 July 2024, 1:48 am EST - Updated 24 July 2024, 1:53 am EST
    I tested with the latest version of SpreadJS and it seems to be working fine at my end. You could refer to the following sample that I have used for testing.
    Sample: https://jscodemine.mescius.io/share/WySZhXsbsEuU8U3653QAEw/?defaultOpen={"OpenedFileName"%3A["%2Fsrc%2Fapp.js"]%2C"ActiveFile"%3A"%2Fsrc%2Fapp.js"}
    Could you kindly share the sample for which you are facing the issue? You may also fork the sample, modify it and share it with us replicating the issue. Also, kindly try with the latest version also.
    You could refer to the following gif that shows the steps I have followed. Let me know if I am missing any step.
    Download SpreadJS Latest version: http://cdn.mescius.com/spreadjs/17.1.1/Files/SpreadJS.Release.17.1.1.zip
    Ankit
