Rename Sheet in Tab Context Menu
Posted by: adisa.craig on 14 March 2025, 11:21 am EST
    Posted 14 March 2025, 11:21 am EST
    I have added a Rename Sheet option to the Tabstrip context menu, is it possible for the rename context menu option, instead of opening a separate dialog box, that it can trigger the sheet tab input to become editable instead, to match the behavior when double clicking the sheet tab
  • Posted 17 March 2025, 8:19 am EST
    There is no direct API available that can simulate the behavior of double-clicking on the sheet name in the sheets tab strip to rename the sheet. However, it is possible to simulate the double-click using JavaScript technology.
    Please refer to the attached code sample that illustrates how to edit the sheet name using the context menu option similar to UI clicks (see below).
    Attachment: RenameSheet.zip
    Kind Regards,
  • Posted 18 March 2025, 1:41 pm EST
    Hi Priyam,
    It seems the
     getActiveSheetTabCoordinates
    fails whenever there is any other content on the page. I added a header div above the spread and the code stopped being able to find the active tab with the hitTest
    RenameSheet.zip
  • Posted 19 March 2025, 2:25 am EST
    Yes, we have observed that the coordinates required for simulating the double click fails. We have updated our solution as per below code :-
          const spreadInstanceID = "ss";
          const tabStripID = `${spreadInstanceID}_tabStrip`;
          const spreadNS = GC.Spread.Sheets;
          const spread = new spreadNS.Workbook(spreadInstanceID);
          let storedCoords = null; // To store right-click coordinates
          // Capture right-click on the tab strip
          const tabStrip = document.getElementById(tabStripID);
          tabStrip.addEventListener("contextmenu", function (event) {
            storedCoords = { x: event.clientX, y: event.clientY };
            console.log("Stored context menu coordinates:", storedCoords);
          // Function to simulate a double click at stored coordinates
          function simulateDoubleClick(coords) {
            setTimeout(() => {
              var canvas = document.getElementById(tabStripID);
              if (!canvas) canvas = document.getElementById("null_tabStrip");
              var event = new MouseEvent("dblclick", {
                bubbles: true,
                cancelable: false,
                clientX: coords.x,
                clientY: coords.y,
                view: window,
              canvas.dispatchEvent(event);
            }, 0);
          // Custom command to rename sheet
          const renameSheetCommand = {
            canUndo: false,
            execute: function () {
              console.log("Executing Rename at:", storedCoords);
              simulateDoubleClick(storedCoords);
          spread.commandManager().register("renameSheetEdit", renameSheetCommand);
          // Add "Rename" option to context menu
          const renameSheet = {
            text: "Rename",
            command: "renameSheetEdit",
            workArea: "sheetTab",
          spread.contextMenu.menuData.push(renameSheet);
    Fixes and Improvements:
    • Stored Coordinates on Right-Click: Now, when the user right-clicks on the tab strip, the exact mouse position is stored.
    • Double Click Simulation: When “Rename” is clicked in the context menu, it simulates a double click at the stored coordinates.
    Sample: index.zip
    Hope this works for you.
  • Posted 24 March 2025, 12:29 pm EST
    Hi Thanks,
    This works for the most part except in cases where the user right clicks a sheet tab that is not the currently active one. Then the input opens in the wrong location. I was trying to debug why this happens as it seems it is getting the right coordinates but it still opens incorrectly.
  • Posted 25 March 2025, 8:13 am EST
    We were able to replicate the issue on our end as well. The cause is unclear, so we have escalated it to the development team. The internal tracking ID is “SJS-28856”. I will update you as soon as we receive any information.
    Priyam
  • Posted 4 April 2025, 6:27 am EST
    The devs have suggested using the approach shown in the snippet below to simulate the double-click behavior when a custom item in the context menu is clicked:
        // console.log(getSheetTabRect(spread, spread.getActiveSheet()));
        console.log(coords)
        setTimeout(() => {
            const canvas = document.getElementById(tabStripID);
            const mousedown = new MouseEvent("mousedown", {
                bubbles: true,
                cancelable: false,
                clientX: coords.x,
                clientY: coords.y,
                view: window,
            canvas.dispatchEvent(mousedown);
            const mouseup = new MouseEvent("mouseup", {
                bubbles: true,
                cancelable: false,
                clientX: coords.x,
                clientY: coords.y,
                view: window,
            canvas.dispatchEvent(mouseup);
            const event = new MouseEvent("dblclick", {
                bubbles: true,
                cancelable: false,
                clientX: coords.x,
                clientY: coords.y,
                view: window,
        }, 0);
    Please refer to the attached sample: Sample.zip
    Best regards,
    Priyam
