Shapes not showing
Posted by: kb on 8 February 2023, 7:59 am EST
    Posted 8 February 2023, 7:59 am EST
    Shapes are not shown in SpreadJs Vue.
    I’ve created a new sjs file with just one rectangle shape in SpreadJs desinger.
    When i load the sjs file in my vuejs application the shape is not shown.
    The sjs file is loaded by fetch api as a blob. All other content is correctly loaded and shown in that file.
    I have imported @grapecity/spread-sheets-shapes in my vue file where the spreadjs component is used.
    My current SpreadJs Version is 16.0.3
    Kind Regards
    Kim
  • Posted 9 February 2023, 3:52 am EST
    the issue seems to be solved.
    I’ ve changed package.json and set all @grapecity/… dependencies from “16.0.3” to “latest” and run another npm install.
  • Posted 9 February 2023, 11:31 pm EST
    Hi Kim,
    We are thrilled to hear that your problem has been solved. In addition to that, I have taken the time to create a test sample which demonstrates how to retrieve a sjs file using the fetch() method, converting the response to a blob, and then loading the blob object into the spread using the spread.open() method.
    It’s important to mention that you will need to have the @grapecity/spread-sheets-shapes and @grapecity/spread-sheets-io packages imported in your project in order to have support for shapes and sjs import/export functionality respectively.
    Please take a look at the code snippet and the sample I have attached for reference.
            // fetching the sjs file
            fetch('file.sjs')
            .then((res) => {
                return res.blob();
            .then((blob) => {
                spread.open(blob, (args) => {
                    console.log('sjs file loaded');
                }, console.log);
    Sample: https://jscodemine.grapecity.com/share/2_i6jrnSSk6Hjuxs8S6mZg/?defaultOpen={"OpenedFileName"%3A["%2Findex.html"%2C"%2Fsrc%2Fapp.vue"]%2C"ActiveFile"%3A"%2Fsrc%2Fapp.vue"}
    Doc reference
    spread.open(): https://www.grapecity.com/spreadjs/api/classes/GC.Spread.Sheets.Workbook#open
    Ankit
