Unable to set GC.Spread.Sheets.LicenseKey
Posted by: wayne.myo on 16 March 2023, 3:36 am EST
  • Posted 16 March 2023, 3:36 am EST - Updated 16 March 2023, 3:44 am EST
    Recently, I purchased SpreadJS 16 Developer License with Maintenance - New License + Single Hostname Deployment License - ANNUAL and I received the license key.
    When I set the license key in my react application according to the instruction from the documentation: https://www.grapecity.com/kb/how-to-set-the-licensekey-in-react, I encountered the gc.spread.sheets.react.min.js:12 Uncaught TypeError: Cannot read properties of undefined (reading ‘name’) at b.a (gc.spread.sheets.react.min.js:12:1) error.
    It’s the same error when I tried out the license key on sample react application provided by Grapecity.
    I’m using SpreadJS version 16.0.2
    @grapecity/spread-sheets”: “16.0.2”,
    @grapecity/spread-sheets-react”: “16.0.2”
    Below is the code snipped of how I’m setting the license key:
    import React, {Component} from 'react';
    import { SpreadSheets, Worksheet, Column } from '@grapecity/spread-sheets-react';
    import GC from '@grapecity/spread-sheets';
    import './Style.css'
    import dataService from '../dataService'
    var SpreadJSKey = "xxxxxxxxxxxxxxx";
    GC.Spread.Sheets.LicenseKey = SpreadJSKey;
    class SpreadSheetsCon extends Component {
        constructor(props) {
            super(props);
            this.state = {
                newTabVisible: true,
                tabStripVisible: true,
                tabStripRatio: true,
                tabNavigationVisible: true,
                scrollbarShowMax: true,
                scrollbarMaxAlign: true,
                showHorizontalScrollbar: true,
                showVerticalScrollbar:true,
                allowUserZoom : true,
                allowUserResize : true,
                spreadBackColor: '#FFFFFF',
                grayAreaBackColor: '#E4E4E4',
            this.hostStyle = {
                top: '90px',
                bottom: '180px'
            this.autoGenerateColumns = false;
            this.data = dataService.getPersonAddressData();
        changeProps(props, value){
            let state = {};
            state[props] = value;
            this.setState(state);
        render() {
            return (
                <div className="componentContainer" style={this.props.style}>
                    <h3>GC-Spread-Sheets</h3>
                    <div>
                        <p>The sample below shows how to bind some properties of spread.</p>
                    </div>
                    <div className="spreadContainer" style={this.hostStyle}>
                        <SpreadSheets newTabVisible={this.state.newTabVisible}
                                      tabStripVisible={this.state.tabStripVisible}
                                      tabStripRatio={this.state.tabStripRatio}
                                      tabNavigationVisible={this.state.tabNavigationVisible}
                                      scrollbarMaxAlign={this.state.scrollbarMaxAlign}
                                      scrollbarShowMax={this.state.scrollbarShowMax}
                                      showHorizontalScrollbar={this.state.showHorizontalScrollbar}
                                      showVerticalScrollbar={this.state.showVerticalScrollbar}
                                      backColor={this.state.spreadBackColor} grayAreaBackColor={this.state.grayAreaBackColor}
                                      allowUserZoom={this.state.allowUserZoom} allowUserResize={this.state.allowUserResize}>
                            <Worksheet dataSource={this.data}
                                       autoGenerateColumns={this.autoGenerateColumns}>
                                <Column width={150} dataField="Name"/>
                                <Column width={150} dataField="CountryRegionCode"/>
                                <Column width={100} dataField="City"/>
                                <Column width={200} dataField="AddressLine"/>
                                <Column width={100} dataField="PostalCode"/>
                            </Worksheet>
                        </SpreadSheets>
                    </div>
                    <div className="settingContainer">
                        <table>
                            <tbody>
                            <tr>
                                <td>
                                    <label><input type="checkbox" checked={this.state.newTabVisible} onChange={(e)=>{this.changeProps('newTabVisible',e.target.checked)}}/>newTabVisible</label>
                                </td>
                                <td>
                                    <label><input type="checkbox" checked={this.state.tabStripVisible} onChange={(e)=>{this.changeProps('tabStripVisible',e.target.checked)}}/>tabStripVisible</label>
                                </td>
                            </tr>
                            <tr>
                                <td>
                                    <label><input type="checkbox" checked={this.state.tabStripRatio} onChange={e => {this.changeProps('tabStripRatio', e.target.checked)}}/>tabStripRatio</label>
                                </td>
                                <td>
                                    <label><input type="checkbox" checked={this.state.tabNavigationVisible} onChange={e => {this.changeProps('tabNavigationVisible', e.target.checked)}}/>tabNavigationVisible</label>
                                </td>
                            </tr>
                            <tr>
                                <td>
                                    <label><input type="checkbox" checked={this.state.scrollbarShowMax} onChange={e => {this.changeProps('scrollbarShowMax', e.target.checked)}}/>scrollbarShowMax</label>
                                </td>
                                <td>
                                    <label><input type="checkbox" checked={this.state.scrollbarMaxAlign} onChange={e => {this.changeProps('scrollbarMaxAlign', e.target.checked)}}/>scrollbarMaxAlign</label>
                                </td>
                            </tr>
                            <tr>
                                <td>
                                    <label><input type="checkbox" checked={this.state.showHorizontalScrollbar} onChange={(e)=>{this.changeProps('showHorizontalScrollbar',e.target.checked)}}/>showHorizontalScrollbar</label>
                                </td>
                                <td>
                                    <label><input type="checkbox" checked={this.state.showVerticalScrollbar} onChange={(e)=>{this.changeProps('showVerticalScrollbar',e.target.checked)}}/>showVerticalScrollbar</label>
                                </td>
                            </tr>
                            <tr>
                                <td>
                                    <label><input type="checkbox" checked={this.state.allowUserZoom} onChange={(e)=>{this.changeProps('allowUserZoom',e.target.checked)}}/>allowUserZoom</label>
                                </td>
                                <td>
                                    <label><input type="checkbox" checked={this.state.allowUserResize} onChange={(e)=>{this.changeProps('allowUserResize',e.target.checked)}}/>allowUserResize</label>
                                </td>
                            </tr>
                            <tr>
                                <td>
                                    <input value={this.state.grayAreaBackColor} type="color" onChange={(e)=>{this.changeProps('grayAreaBackColor',e.target.value)}}/> grayAreaBackColor
                                </td>
                                <td>
                                    <input value={this.state.spreadBackColor} type="color" onChange={(e)=>{this.changeProps('spreadBackColor',e.target.value)}}/> backColor
                                </td>
                            </tr>
                            </tbody>
                        </table>
                    </div>
                </div>
    export default SpreadSheetsCon
    Can someone help me on the issue? I’ve been googling for awhile and couldn’t find any solution to this.
  • Posted 17 March 2023, 2:03 am EST
    Apologies, but we are unable to reproduce the issue on our end. To help you further, could you please provide a working sample that replicates the issue? We recommend sharing the sample in the support portal and not in public forums, especially without the key. We have also tested a sample that you can refer to using this link:
    https://jscodemine.grapecity.com/share/s1W75IVTrUKIh0zM0Cr2-w/?defaultOpen={"OpenedFileName"%3A["%2Findex.html"%2C"%2Fsrc%2Fapp.jsx"]%2C"ActiveFile"%3A"%2Fsrc%2Fapp.jsx"}.
    regards,
    Avinash
