Posted 17 September 2017, 2:10 pm EST
There is a way to set the minute step?
i don’t want the full list (1,2,3,4,5,6…) but instead i would this short list (0,15,30,45)
Thank’s
Forums Home / ComponentOne / UWP Edition
Posted by: roberto_tomasi on 17 September 2017, 2:10 pm EST
Thank’s
Posted 19 September 2017, 12:53 am EST
I escalated this to concern team. Will let you know as soon as there is any information from them.
Singh
Posted 19 September 2017, 2:59 am EST
You can find the minutes combobox and change its ItemsSource.
See the below code:
<c1:C1DateTimeSelector Height="60" x:Name="dts" />
public sealed partial class MainPage : Page
List<int> data = new List<int> { 0, 15, 30, 45, 60};
public MainPage()
this.InitializeComponent();
Loaded += MainPage_Loaded;
private void MainPage_Loaded(object sender, RoutedEventArgs e)
this.Dispatcher.RunAsync(Windows.UI.Core.CoreDispatcherPriority.Low, () =>
var minute = dts.GetChildren<ComboBox>().Where(el => el.Name.Equals("MinutesList")).FirstOrDefault();
if (minute != null)
minute.ItemsSource = data;
minute.ItemTemplate = null;
minute.SelectedIndex = 0;
public static class Extensions
public static IEnumerable<DependencyObject> GetChildren(this FrameworkElement elem, bool includeSelf = true, bool recursive = true)
if (elem == null) yield break;
if (includeSelf) yield return elem;
FrameworkElement current = elem;
for (int i = 0; i < VisualTreeHelper.GetChildrenCount(elem); i++)
var child = VisualTreeHelper.GetChild(elem, i);
yield return child;
if (recursive && child is FrameworkElement)
foreach (var item in (child as FrameworkElement).GetChildren(false, true))
yield return item;
public static IEnumerable<T> GetChildren<T>(this FrameworkElement elem) where T : FrameworkElement
return elem.GetChildren().Where(e => e is T).Select(e => e as T);
Singh Sonu
Posted 27 September 2017, 1:58 pm EST
Thank’s a lot for reply but I would be very grateful for Visual Basic Translate
Posted 28 September 2017, 12:54 am EST
Please find the VB code below:
<my:C1DateTimeSelector Height="60" x:Name="dts"/>
Partial Public NotInheritable Class MainPage
Inherits Page
Private data As New List(Of Integer)() From {
0,
15,
30,
45,
60
Public Sub New()
Me.InitializeComponent()
AddHandler Loaded, AddressOf MainPage_Loaded
End Sub
Private Async Sub MainPage_Loaded(sender As Object, e As RoutedEventArgs)
Await Dispatcher.RunAsync(CoreDispatcherPriority.Normal, Function()
Dim minute = FindChild(Of ComboBox)(dts, "MinutesList")
If minute IsNot Nothing Then
minute.ItemTemplate = Nothing
End If
Return 0
End Function)
End Sub
''' <summary>
''' Finds a Child of a given item in the visual tree.
''' </summary>
''' <param name="parent">A direct parent of the queried item.</param>
''' <typeparam name="T">The type of the queried item.</typeparam>
''' <param name="childName">x:Name or Name of child. </param>
''' <returns>The first parent item that matches the submitted type parameter.
''' If not matching item can be found,
''' a null parent is being returned.</returns>
Public Function FindChild(Of T As DependencyObject)(parent As DependencyObject, childName As String) As T
' Confirm parent and childName are valid.
If parent Is Nothing Then
Return Nothing
End If
Dim foundChild As T = Nothing
Dim childrenCount As Integer = VisualTreeHelper.GetChildrenCount(parent)
For i As Integer = 0 To childrenCount - 1
Dim child = VisualTreeHelper.GetChild(parent, i)
' If the child is not of the request child type child
Dim childType As T = TryCast(child, T)
If childType Is Nothing Then
' recursively drill down the tree
foundChild = FindChild(Of T)(child, childName)
' If the child is found, break so we do not overwrite the found child.
If foundChild IsNot Nothing Then
Exit For
End If
ElseIf Not String.IsNullOrEmpty(childName) Then
Dim frameworkElement = TryCast(child, FrameworkElement)
' If the child's name is set for search
If frameworkElement IsNot Nothing AndAlso frameworkElement.Name = childName Then
' if the child's name is of the request name
foundChild = DirectCast(child, T)
Exit For
End If
Else
' child element found.
Exit For
End If
Next
Return foundChild
End Function
End Class
Singh Sonu
Posted 23 October 2017, 12:05 pm EST
Hi
thanks for your reply but not works fine
I insert the TimeSelector into a C1TabControl
it works only in the first TabItem
in the others TabItem not works because this line
return 0
Posted 3 November 2017, 8:47 am EST
Help Please
Posted 6 November 2017, 1:46 am EST
Yes, I could replicate the same issue at my end and escalated this to concern team. Will let you know as soon as there is any information from them.
(Tfs id: 286433 for internal use only)
Singh
Posted 9 November 2017, 2:51 am EST
It might be a limitation to implement this request in an easy way. As investigated, I provided a workaround to make this request. Please refer to attached sample.
Singh
