FlexViewer - Exception in rendered text, but none thrown
Posted by: andreas.fischer on 11 September 2018, 9:11 am EST
    Posted 11 September 2018, 9:11 am EST - Updated 30 September 2022, 9:09 am EST
    Hello again :wink:
    I have an exception inside the rendered Document, as Documentcontent. But no exception is thrown. The PDF openes fine with other frameworks and with Adobes PDF-Reader.
    Is there a way to get the exception in code at runtime?
    Best regards,
    Andreas
  • Posted 12 September 2018, 5:36 am EST
    I can confirm the following.
    Making Preflight checks in Acrobat tells, that there are “more than one encoding in cmap for a truetype font”.
    Converting the PDF to PDF/A (fonts are converted to postscript) solves the problem with flexviewer.
    However, other frameworks do render the pdf just fine, since this is not a critical error but mere are warning in preflight, flexviewer should be able to render that too - maybe you can handle that exception?
  • Posted 12 September 2018, 6:05 am EST
    Hi Andreas,
    Could you share the pdf file you are observing the exception with. I tried to check the issue but using the default pdf in our product sample ‘PdfView’ (installed at \Documents\ComponentOne Samples\UWP\C1.UWP.Document\CS\PdfView location) along with one of the latest versions, I did not observe any exception.
    Therefore, request you to share your pdf.
    Also, to trap the exception in code, did not the try-catch block work ?
    Ruchir
  • Posted 12 September 2018, 8:05 am EST
    Hi Ruchir,
    yes I tried to catch anything, but nothing was thrown - not even with having all runtime exceptions checked in visualstudio to break at.
    The PDF in question is confidential, but I stripped it down to just one word and attached it here. The error still occurs. I would like to send you one complete page of the pdf which has additional ormultiple erros in flexviewer. But non-public. Do you have a pm where I can send it to you?
    Best regards,
    Andreastest_fonterror.zip
  • Posted 14 September 2018, 6:31 am EST
    Hi Andreas,
    I have created a new case in our Portal asking you to share the pdf file there. Kindly share the file. Here is the link for the case:
    http://supportone.componentone.com/home/casedetail/343045
    Pragati
  • Posted 27 November 2018, 10:59 am EST
    Any news on this? It has been more than two months.
    And sadly the case link (http://supportone.componentone.com/home/casedetail/343045) dosen’t exist anymore.
  • Posted 28 November 2018, 12:30 am EST
    I do not know why you were not able to find the case because I still can open the same using http://supportone.componentone.com/casedetail/343045 URL. Also, I have responded you over there.
    ~Ruchir
