Using Complex Business Objects with the Report Viewer
Posted by: daniel on 27 June 2018, 7:14 pm EST
    Posted 27 June 2018, 7:14 pm EST
    Hi I'm trying to use a complex business object as my Report Data Source and then trying to access properties on another complex business object which is a property of the first, in the report.
    Ex: Business might have StreetAddress and I'm trying to access StreetAddress.StreetNumber from a textbox.
    When I tried something similar in my application it gave me the namespace of the object (ProjectName.StreetAddress) as the textboxes output. Is there a way to do what I'm trying to do?
    Daniel
  • Posted 1 July 2018, 11:00 pm EST
    Hello Daniel,
    I am investigating on your requirement and will get back to you soon with a solution.
    ~Ruchir
  • Posted 3 July 2018, 8:03 am EST
    Hi Daniel,
    After investigation, we found that though there is not a direct way to achieve your requirement. However, by accessing the nested properties via reflection, it can still be done. For complete implementation, please refer the attached sample application.
    Ruchir
    FlexReport_Nested.zip
