C1GridView - Filtering Glitch On Postback
Posted by: ifdadmin on 14 August 2024, 4:26 pm EST
    Posted 14 August 2024, 4:26 pm EST - Updated 14 August 2024, 4:32 pm EST
    Alright, so my previous issue being solved, I finally had a working C1GridView, and it filtered SLICK!
    Awesome.
    Because I’m a huge fan of “DRY” code and don’t like to re-write code bits over and over again, I had written a special static method years ago that’s served me well to “scrape” an entire GridView of data and shove it all in a DataTable. After I worked out the initial kinks in the method, it’s served me very well for years - until it came across the C1GridView.
    I modified the method to just take in a C1GridView instead of a Microsoft GridView, and it doesn’t error, but it does provide some strange results.
    Image 1 shows the onscreen results after I’ve filtered the results down to only those records that contain “1” within the description. This is the data that I want to “scrape” after the postback.
    Image 2 shows the results in the Microsoft Data Visualizer for the DataTable that my code “scraped”. At first, I thought that there was something wrong with my method, so I dug in and investigated. If you run it yourself, and set a break-point at line 35 of ASP.cs, you’ll see that while the GridView DOES contain 11 rows after the post-back, it does indeed contain the FIRST eleven rows of the original dataset, NOT the filtered down dataset, just like it shows in the picture!
    If you investigate each object and each control during runtime using the debugger and navigate through all of them, you’ll see that this is indeed true.
    So, is there something that I’m missing here? How do I get the filtered down results from the GridView after postback?
    I’ve uploaded a full “bare minimum reproducable” code based on the original code that Mescius sent me, with just “my” stuff added to their code to reproduce the error.
    You can find the full code here on my GitHub: https://github.com/WestBennett/C1GridViewOddity
    I’ll take it down when the issue is resolved.
  • Posted 18 August 2024, 11:51 pm EST
    Hey,
    Apologies for the delay caused by the long public holiday, we tried running your sample but faced some trouble running it.
    Our team is on it and will get back to you soon!
    Thanks for your patience.
    Anand
  • Posted 19 August 2024, 3:45 pm EST
    Let me know if you need anything from me.
  • Posted 20 August 2024, 3:04 am EST - Updated 20 August 2024, 3:26 am EST
    Thanks for the sample application. I was able to reproduce this behavior at my end. I have reported this to the development team[C1WEB-29759] and will get back to you once I have any information on the same.
  • Posted 28 August 2024, 3:13 am EST
    I just got an update from the development team. This seems to be a bug. The filter’s setting is kept at the column after callback however, it doesn’t take any effect into the display rows. The development team has shared the attached workaround.
    P.S. I have deleted the DLLs from the sample to reduce the size of the application. Please check the Page_Load event in Default.aspx.cs script file.
    C1GridView_Filter.zip
  • Posted 3 January 2025, 10:18 am EST
    I’m finally getting around to this now, as I was pulled to other projects. Has a fix been implemented for this bug? I’ve got the workaround implemented in my code, and I’ll be testing it today, but it would be good to know whether or not the source issue was resolved.
  • Posted 10 January 2025, 6:32 pm EST
    Letting you know that the “ifdadmin” account has been disabled. This is my new account.
  • Posted 13 January 2025, 5:13 am EST
    Hi Westley,
    I have asked the development team for a update on the case and will get back to you once I have any updates for the same.
  • Posted 15 January 2025, 2:19 am EST
    Hi Westley,
    I have update from the development team on this. Currently we do not have any exact ETA for this however you can expect the issue to be fixed with the 2025 v1 release(i.e. May 2025).
