C1webgrid doesn't have RowDataBound event
Posted by: kbeyene on 17 January 2018, 10:27 am EST
    Posted 17 January 2018, 10:27 am EST
    I am trying to do nested grid using c1webgrid. User be able to see child grid on click of master grid how ever c1webgrid doesn’t have
  • Posted 18 January 2018, 3:03 am EST
    Please refer to the following demo sample to add Grid inside grid:
    http://demo.componentone.com/aspnet/ControlExplorer/C1GridView/HierarchicalGrid.aspx
    Let us know if you have any further queries.
    ~Manish
  • Posted 19 December 2018, 4:43 am EST
    You may try this code.
    Binding the Customers records to the Parent GridView
    protected void Page_Load(object sender, EventArgs e)
    if (!IsPostBack)
    gvCustomers.DataSource = GetData(“select top 10 * from Customers”);
    gvCustomers.DataBind();
    private static DataTable GetData(string query)
    string strConnString = ConfigurationManager.ConnectionStrings[“constr”].ConnectionString;
    using (SqlConnection con = new SqlConnection(strConnString))
    using (SqlCommand cmd = new SqlCommand())
    cmd.CommandText = query;
    using (SqlDataAdapter sda = new SqlDataAdapter())
    cmd.Connection = con;
    sda.SelectCommand = cmd;
    using (DataSet ds = new DataSet())
    DataTable dt = new DataTable();
    sda.Fill(dt);
    return dt;
    Binding the Child GridView with the Orders for each Customer in the Parent GridView
    protected void OnRowDataBound(object sender, GridViewRowEventArgs e)
    if (e.Row.RowType == DataControlRowType.DataRow)
    string customerId = gvCustomers.DataKeys[e.Row.RowIndex].Value.ToString();
    GridView gvOrders = e.Row.FindControl(“gvOrders”) as GridView;
    gvOrders.DataSource = GetData(string.Format(“select top 3 * from Orders where CustomerId=‘{0}’”, customerId));
    gvOrders.DataBind();
    Client side Expand Collapse functionality using jQuery and JavaScript
