Disable using JQUERY a C1InputDate (ASP.Net Wijmo 4.0) control
Posted by: fvicente on 7 November 2018, 2:03 am EST
    Posted 7 November 2018, 2:03 am EST
    In JavaScript:
    $ (“# ctlInputDate”). prop (“disabled”, true);
    It code only disable changes writing in the control but if you use the mouse and make a Click it shows the calendar !. So the control is not disable totally!
    I need to disable the full control like ASP.Net: ctlInputDate.Enable = false;
    What should I do?
    Some body have the solution?
  • Posted 8 November 2018, 7:29 am EST
    We are working on it. Will update you soon.
  • Posted 9 November 2018, 2:07 pm EST
    Please try this code & let me know if it works for you.
    var q = document.querySelector(".wijmo-wijinput");
    q.addEventListener(
      "click",
      function(e) {
        e.preventDefault();
        e.stopPropagation();
      true
  • Posted 12 November 2018, 9:45 pm EST
    I made the changes and It doesn’t work!
  • Posted 13 November 2018, 1:48 am EST
    Please use the following code snippet to disable InputDate control using JavaScript same as C1InputDate.Enable=false property.
    $("#C1InputDate1").c1inputdate("option", "disabled", true);
    It should work for you!
    ~Manish
  • Posted 25 November 2018, 11:31 am EST
    Hi Manish
    Thank you so much! It works perfect with the last version of controls!
    Bye bye.
