Excel in ASP.NET using Gridview
Posted by: rsayers on 10 September 2017, 11:42 am EST
  • Posted 10 September 2017, 11:42 am EST
    I am attempting to import an excel spreadsheet into a C1WebGrid. I have used the example from another forum topic, http://our.componentone.com/groups/asp-net/studio-for-asp-net/forum/topic/excel-for-asp-net/, to no avail. I have set the AutoGenerateColumns=“true” in the .aspx and coded the example’s GetDataTable and LoadSpeadSheet functions. I’ve also coded the grid’s DataBound event to add the columns of the datatable to the grid. However, the grid never displays on my web page. Do you have a complete code sample using C1.C1Excel.2 and C1.Web.C1WebGrid.2?
    Thank you for your time and effort,
    Rodney
    Hello Rodney,
    Unfortunately we officially ended support on March 16th 2011 of the C1WebGrid :
    http://www.componentone.com/SuperPages/PressReleases/?newsID=45
    But we do support C1GridView (C1WebUI and Wijmo). I am attaching a sample for loading an excel file in Wijmo grid. You can use same code for C1GridView (C1WebUI).
    Let me know in case you have further queries.
    Richa
    2011/11/Sample_WijGrid.zip
    Richa,
    Thank you for the reply and the example. I have tried the example you provided using the C1GridView with no success.
    The following is the aspx markup…
    <%@ Page Title=“” Language=“vb” AutoEventWireup=“false” MasterPageFile=“~/DCI.Web.Core.Master” CodeBehind=“CRD0210.aspx.vb” Inherits=“DCI.Web.Core.CRD0210” %>
    <%@ Register Assembly=“C1.Web.UI.Controls.3” Namespace=“C1.Web.UI.Controls.C1GridView” TagPrefix=“C1gv” %>
    <asp:Content ID=“fpContent” ContentPlaceHolderID=“cphMisc” runat=“server”>
    </asp:Content>
    <asp:Content ID=“Content1” ContentPlaceHolderID=“ContentPlaceHolder1” runat=“server”>
    <asp:UpdatePanel ID=“UpdateContent” runat=“server”>
    …(I’ve remove a large unrelated portion)…
            <act:CollapsiblePanelExtender ID="cpeDepartment" runat="server" Enabled="True" TargetControlID="pnlDepartment"
                Collapsed="false" CollapsedImage="<%$ Image: CollapseBottom %>" ExpandedImage="<%$ Image: CollapseTop %>"
                CollapseControlID="imgDepartmentPanel" ExpandControlID="imgDepartmentPanel" ImageControlID="imgDepartmentPanel"
                SuppressPostBack="True">
            </act:CollapsiblePanelExtender>
            <table width="100%" style="border-collapse: collapse;">
                <tr>
                    <td class="SubHeaderSection" valign="bottom">
                        EXCEL
                    </td>
                    <td align="right" class="SubHeaderSection" valign="bottom">
                        <asp:ImageButton ID="imgDepartmentPanel" runat="server" CausesValidation="False"
                            ImageUrl="<%$ Image: CollapseTop %>" ToolTip="Show/Hide Department panel" />
                    </td>
                </tr>
            </table>
            <asp:Panel ID="pnlDepartment" runat="server">
                <table width="100%">
                    <tr>
                        <td>
                            <C1gv:C1GridView ID="gvDepartments" runat="server" Height="250px" Width="750px"
                                ScrollSettings-ScrollMode="ScrollBar" ScrollSettings-ScrollOrientation="Both"></C1gv:C1GridView>
                        </td>
                    </tr>
                </table>
            </asp:Panel>
        </ContentTemplate>
    </asp:UpdatePanel>
    The following is the VB code behind…
    this is in a button function…
    gvDepartments.DataSource = GetDataTable()
    gvDepartments.DataBind()
    Public Function GetDataTable() As DataTable
        Try
            xlBook = LoadSpreadSheet(Server.MapPath("Book1.xlsx"))
            XLSheet = xlBook.Sheets(0)
            dtSheet = New DataTable(XLSheet.Name)
            Dim intColumn As Integer = 0
            For i As Integer = 0 To XLSheet.Columns.Count - 1
                'The fourth row contains the column titles...
                If XLSheet(3, i).Value IsNot Nothing Then
                    If XLSheet(3, i).Value.ToString.Trim.Length > 0 Then
                        dtSheet.Columns.Add(XLSheet(3, i).Value.ToString)
                    Else
                        intColumn += 1
                        dtSheet.Columns.Add("Column " + intColumn.ToString)
                    End If
                End If
            Next
            For i As Integer = 0 To XLSheet.Rows.Count - 1
                Dim drSheet As DataRow = dtSheet.NewRow
                For c As Integer = 0 To dtSheet.Columns.Count - 1
                    If xlSheet.GetCell(i, c) IsNot Nothing AndAlso _
                       xlSheet.GetCell(i, c).Value IsNot Nothing AndAlso _
                       xlSheet.GetCell(i, c).Value.ToString.Trim.Length > 0 Then
                        drSheet(c) = xlSheet.GetCell(i, c).Value.ToString
                    Else
                        drSheet(c) = String.Empty
                    End If
                Next
                dtSheet.Rows.Add(drSheet)
            Next
        Catch ex As Exception
            GlobalException.ThrowException(Me.ToString, System.Reflection.MethodBase.GetCurrentMethod.Name, Nothing, ex)
        End Try
    End Function
    Public Function LoadSpreadSheet(ByVal strPath As String) As C1XLBook
        Try
            xlBook = New C1XLBook
            xlBook.Load(strPath, FileFormat.OpenXml, True)
        End Try
        Return xlBook
    End Function
    Follows is a Firebug representation after the page is rendered…
    I’ve also attached the spreadsheet I’m trying to load.
    As you can see, the column group is empty.
    What could I be doing incorrectly?
    Thank you, again, for you time and effort,
    Rodney
    2011/11/Book1.xlsx
  • Posted 23 January 2019, 1:15 am EST
    Try oledb…
                System.Data.OleDb.OleDbConnection MyConnection ;
                System.Data.DataSet DtSet ;
                System.Data.OleDb.OleDbDataAdapter MyCommand ;
                MyConnection = new System.Data.OleDb.OleDbConnection("provider=Microsoft.Jet.OLEDB.4.0;Data Source='c:\\csharp.net-informations.xls';Extended Properties=Excel 8.0;");
                MyCommand = new System.Data.OleDb.OleDbDataAdapter("select * from [Sheet1$]", MyConnection);
                MyCommand.TableMappings.Add("Table", "TestTable");
                DtSet = new System.Data.DataSet();
                MyCommand.Fill(DtSet);
                dataGridView1.DataSource = DtSet.Tables[0];
                MyConnection.Close();
    More on…asp.net gridview
    http://asp.net-informations.com/gridview/asp-gridview.htm
