Wijmo Grid
Posted by: cesar.smerling on 7 February 2020, 3:33 pm EST
    Posted 7 February 2020, 3:33 pm EST
    Hi, im using angular and wijmo grid in angular, and boostrap, is there a way to hide de columns on width changes?
  • Posted 9 February 2020, 11:27 pm EST
    Hi Cesar,
    You may hide a column of the FlexGrid by setting its visible property to false:
    flexGrid.columns.getColumn('country').visible = false;
    But, we were unable to understand your requirement about hiding the column when the width changes. Could you please explain more about your use case so that we can assist you further?
  • Posted 10 February 2020, 8:45 am EST
    Hi! I have a grid that is contained in a div that the width changes on some user iteractions. When the width shrinks I want that some of the columns will be hidden, I’m using for the columsn the '’ some cases has 1 other 0.5*.
    Here is the grid code:
     <wj-flex-grid #flexBaselines class="scs-grid-list" style="border-top: 0!important;"
                      [itemsSource]="itemSource"
                      [headersVisibility]="'Column'"
                      [selectionMode]="'Row'"
                      [isReadOnly]="true"
                      (initialized)="initSelector(flexBaselines)"
                      (loadedRows)="loadedRows.emit($event)"
                      (selectionChanged)="selectBaseline($event)">
            <wj-flex-grid-column
                [header]="'lbl.Timestamp' | translate"
                [binding]="'timestamp'" [width]="'1*'">
                <ng-template wjFlexGridCellTemplate [cellType]="'Cell'" let-item="item">
                            <span>
                                <b>{{dateUtils.getTimestampAsLLL(item.timestamp)}}</b>
                            </span>
                </ng-template>
            </wj-flex-grid-column>
                [header]="'lbl.Identification' | translate"
                [binding]="'identification'" [width]="'1*'">
                    <span>{{item.identification}}</span>
                </ng-template>
                [header]="'lbl.Tag' | translate"
                [binding]="'tag'" [width]="'1*'">
                    <span>{{item.tag ? item.tag : ''}}</span>
    <!--                <span class="font-weight-light">{{item.tag ? item.tag : ''}}</span>&lt;!&ndash;&ndash;&gt;-->
                </ng-template>
                [header]="'lbl.Type' | translate"
                [binding]="'type'" [width]="'0.5*'">
                    <i class="{{findBaselineType(item.type).icon}} mr-2"></i>{{item.type}}
                </ng-template>
                [header]="'lbl.From' | translate"
                [binding]="'fromScenario'" [width]="'0.5*'">
                    <div *ngIf="item.fromScenario">
                                    <span class="badge badge-primary">
                                       {{findScenario(scenarios, item.scenarioId).name}}
                                    </span>
                    </div>
                    <div *ngIf="!item.fromScenario">
                                <span class="badge badge-danger">
                                    {{findFolder(folders, item.folderId).name}}
                                </span>
                    </div>
                </ng-template>
            <wj-flex-grid-column [width]="'0.3*'">
                    <div ngbDropdown class="d-flex justify-content-center" container="body">
                        <button id="dropdownSelectorActions" ngbDropdownToggle
                                class="btn btn-sm btn-light ">
                            <i class="fas fa-ellipsis-h"></i>
                        </button>
                        <div ngbDropdownMenu aria-labelledby="dropdownSelectorActions">
                            <button ngbDropdownItem class="d-flex align-items-center"
                                    (click)="editClicked.emit(item)">
                                {{'btn.Edit' | translate}}
                                <span class="d-flex flex-nowrap ml-auto">
                                        <i class="fas fas fa-arrow-right"></i>
                                    </span>
                            </button>
                                    (click)="importClicked.emit(item)">
                                {{'btn.Import' | translate}}
                                        <i class="fas fas fa-file-download"></i>
                                    </span>
                            </button>
                                    (click)="exportClicked.emit(item)">
                                {{'btn.Export' | translate}}
                                        <i class="fas fas fa-file-upload"></i>
                                    </span>
                            </button>
                                    (click)="removeClicked.emit(item)">
                                {{'btn.Remove' | translate}}
                                        <i class="fas fas fa-trash text-danger"></i>
                                    </span>
                            </button>
                        </div>
                    </div>
                </ng-template>
        </wj-flex-grid>
    I was wondering if there is some css class or the same width as '*'function that could help me to hide the columns. If not I have to react to the user iteractions and hide and show columns and add reactive screen size reaction too (I want to know if the grid can help me not to do that).
    PD: Sorry for the Post title.
  • Posted 11 February 2020, 1:34 am EST
    Hi Cesar,
    As per our understanding, you wish to hide a few columns when the width of the FlexGrid is less than some value. Please refer to the demo link below that shows how you can change the layout of the FlexGrid for different screen widths:
    https://www.grapecity.com/wijmo/demos/Grid/Responsive/angular
    If you will reduce the window size, the FlexGrid will also change its layout.
    Let us know if this helps.
  • Posted 13 February 2020, 8:19 am EST
    Thanks, with the ```
    this.flex.addEventListener(window, ‘resize’, this._updateGridLayout.bind(this));
  • Posted 13 February 2020, 11:20 pm EST
    Hi Cesar,
    We are glad that you were able to resolve the issue.
