Access column data from within dataMap.getDisplayValues
Posted by: rusty on 14 June 2021, 2:45 pm EST
    Posted 14 June 2021, 2:45 pm EST
    Hi, I am using the dataMap.getDisplayValues method as I need to create a Dynamic Datamap that returns a subset of the values based on the row data.
    Is there a way to access the column data from within the getDisplayValues method?
    I only need access to the dataMap property of the column.
  • Posted 15 June 2021, 1:02 pm EST
    Hi Rusty,
    Since getDisplayValues is a regular function in javascript you may access the column properties as close inside the getDisplayValues like:
    var theGrid = new wijmo.grid.FlexGrid('#app', {
        autoGenerateColumns: false,
        columns: [
          { binding: 'country', header: 'Country' },
          { binding: 'city', header: 'City' }
        itemsSource: getData()
    // create map
    var cityMap = new DataMap(getCities(), 'id', 'name');
    // override getDisplay values
    cityMap.getDisplayValues = function(rowDataItem) {
        console.log(rowDataItem);
        // access column properties
        let col = theGrid.columns.getColumn("city");
        console.log(col.binding);
        let validCities = getCities().filter(
          city => city.country == rowDataItem.country
        return validCities.map(city => city.name);
    // assign data map
    theGrid.columns.getColumn("city").dataMap = cityMap;
