Posted 2 April 2020, 5:58 am EST
Hi Team,
When I copy paste a value and try to add a new record while pasted cell/row is till highlighted, the new row doesn’t get added. Only after I click elsewhere the row appears. Is this an expected behavior or is something wrong here?
Also we try to format the newly added row, in our application which is also breaking as the row isn’t appearing. Below is the code we use to format:
sheet._rows.forEach(function (record, index) {
if (record._data.recored.ID == "" || record._data.record.ID == null) {
sheet.applyCellsStyle({
backgroundColor: HEX_GRAY
}, [new wijmo.grid.CellRange(index, range._col, index, range._col + 1)]);
backgroundColor: HEX_YELLOW
}, [new wijmo.grid.CellRange(index, range._col + 2, index, range._col + 5)]);
Also, here’s an example with the wijmo version we’re currently using in our application.
https://fkuku.csb.app/
Keerthana
