Adding New Row in Wijmo Grid with dynamic collection for a column& preselection
Posted by: technical.store.technical on 27 May 2021, 9:06 am EST
    Posted 27 May 2021, 9:06 am EST
    Can you please provide us a small demo in which we want to bind new dropdown collection to a newly added row with its preselection.
    For example -
    We have added a new blank row in below snippet. But on selection of one of the element from section column we need to show different dropdown collection for subject column for that particular new row.
    Example - Subject dropdown collection can be [1,2,3] instead of [‘english’, ‘maths’, ‘Computers’, ‘physics’, ‘chemistry’] and in this we also need to show ‘All’ as preselected.
    https://stackblitz.com/edit/angular-wvvf7h?file=src/app/app.component.html
    Please provide solution.
    Thank You.
  • Posted 27 May 2021, 9:10 am EST
    Also in above snippet , we are unable to add new row at the top.
    For that we have used [newRowAtTop] = true.
    Thank You.
  • Posted 28 May 2021, 12:03 am EST
    Please help us with the solution.
    Thank You.
  • Posted 29 May 2021, 5:42 am EST
    Thank You.
  • Posted 31 May 2021, 12:04 am EST
    We apologize for the delay, we are currently investigation this and will provide you an update soon.
  • Posted 31 May 2021, 5:29 am EST
    Can you also let us know how to add click event on cell or column.
    Thank You.
  • Posted 31 May 2021, 11:10 pm EST
    Sorry for the delay, please refer to the following sample that demonstrates how we could add the newly added row at top, and show a different list of subjects for new items and existing items.
    https://stackblitz.com/edit/angular-jcmet5?file=src%2Fapp%2Fapp.component.ts
    To handle click events, we may add mousedown listener on the grid’s hostElement and use hitTest() method to determine which row/column was clicked. You may refer to the above shared sample or the following code snippet:
    grid.hostElement.addEventListener('mousedown', e => {
          let ht = grid.hitTest(e);
          let htInfo = '';
          htInfo += `area: ${wjGrid.CellType[ht.panel.cellType]}`;
          htInfo += `\nrowIndex: ${ht.row}`;
          htInfo += `\ncolIndex: ${ht.col}`;
          if (this.showClickAlert) {
            alert(htInfo);
  • Posted 1 June 2021, 3:29 am EST
    Hi Admin,
    Thanks for solution.
    But In above snippet we just changed the type of section column. We have added the [cellType]=“‘Cell’” and [(selectedItem)]=“cell.item.section”.
    After this we can see on adding new row, the section cell of new row is not getting cleared even though we are clearing it from ts file.
    For Example -
    addNewUser() {
    const newItem = {
    section: ‘’,
    subjects: this.additionalSubjects,
    isNew: true
    Snippet of above code -
    https://stackblitz.com/edit/angular-lrhbq4?file=src/app/app.component.ts
    Can you please help in this.
    Thank You.
  • Posted 2 June 2021, 2:00 pm EST
    Thank you for the sample.
    To allow empty values in combobox, we need to set the isRequired property of ComboBox to false. You may refer to the following updated sample:
    https://stackblitz.com/edit/angular-8rw4de?file=src%2Fapp%2Fapp.component.html
  • Posted 3 June 2021, 12:09 am EST
    Hi Sharad,
    Thank you for responding.
    This works.
    Thank You.
