Adding vertical scrollbar in wijmo listbox
Posted by: nivishapanwar on 3 February 2021, 4:51 am EST
  • Posted 3 February 2021, 4:51 am EST
    Hi ,
    I am using wijmo listbox and added like same as in the example given in the grapecity, but I am not able to add a vertical scrollbar in the listbox.
    <wj-list-box #ListData [itemsSource]=“name”
    (selectedIndexChanged)=“displayListBoxValueInTextField(ListData)”>
    Nivisha
  • Posted 4 February 2021, 6:19 am EST
    Hi Nivisha,
    You will need to set the height CSS property of the listbox and then only vertical scrollbars will be displayed:
    .wj-listbox{
    	height: 400px;
  • Posted 4 February 2021, 8:16 am EST
    Hi Ashwin,
    Will I be able to get the scrollbar if I keep height as auto as if I keep it as 400 px, the listbox is coming out of the container .
    Nivisha
  • Posted 4 February 2021, 11:15 pm EST
    Hi Nivisha,
    Setting auto as the height will display all the elements in the ListBox and a scrollbar will not be displayed.
    You can try setting the height to 100% so it will not move outside the container.
